Help Quick: Cutting the crossmember 4, hacksaw??? hammer???
Old Aug 21, 2002 | 04:31 PM
pelotudo's Avatar
Default Help Quick: Cutting the crossmember 4, hacksaw??? hammer???
I need about 1 1/2" - 2" to be cut/beaten out of my cross member in order for my DP to fit. What can I use to do this w/o having to drop the freaking thing? Will a hacksaw cut it, and would you guys recommend it?
jB
Old Aug 21, 2002 | 05:01 PM
BoostedED9's Avatar
Default Re: Help Quick: Cutting the crossmember 4, hacksaw??? hammer??? (PeloTudo)
drop it and take a sledge hammer to it
Old Aug 21, 2002 | 05:04 PM
EL Vap133's Avatar
Use a saws-all/reciprocating saw, works great on metal and it's electric....
Old Aug 21, 2002 | 05:07 PM
civbeater90's Avatar
Default Re: Help Quick: Cutting the crossmember 4, hacksaw??? hammer??? (Vap133)
you might be able to get away with a dremel also with the heavy duty cutting wheels.i used one to cut through part of the radiator support area.
Old Aug 21, 2002 | 05:10 PM
dustin's Avatar
Default Re: Help Quick: Cutting the crossmember 4, hacksaw??? hammer??? (civbeater90)
die grinder w/ cutoff wheel
Old Aug 21, 2002 | 06:19 PM
pelotudo's Avatar
Default Re: Help Quick: Cutting the crossmember 4, hacksaw??? hammer??? (dustin)
We tooks care of it:
Angle grinder to it... Like a hot knife thru butta.
Crossmember out of the way...Tomorrow, FMIC piping... Turbo is getting closer and closer.
jB
gooblinn258
18
Sep 13, 2014 04:23 AM
bigD
Welding / Fabrication
11
Dec 27, 2007 02:15 AM
EJ8 GSR-T
Aug 15, 2005 05:28 AM
john d
Dec 23, 2004 06:56 AM
racerxadam
Aug 6, 2003 02:24 PM
