Ring Gap Question before assembly
Old Jun 28, 2009 | 04:22 PM
precisionsc54's Avatar
Default Ring Gap Question before assembly
GSR block: bored, decked, - 81.5 mm bore
- Piston-to-wall clearance: .004
- Wiseco 81.5 mm (B18C) pistons Part # K541M815
- Wiseco Rings (came with the pistons) Part #
Now my question is this. The machine shop told me that the rings came pregapped at 12thousands. What kind of actual gap should I be looking for? Also how far down in the sleeve do you put the rings to take the measurement. I plan on making 400-450hp on a turbo setup. I know wrong forum but you guys are more helpful
Old Jun 28, 2009 | 04:31 PM
DonF's Avatar
Default Re: Ring Gap Question before assembly
Check them yourself to see what they are. Only a feeler guage required. If the bore is round and has no taper you can check anywhere as long as the ring is squared. Use your turbo piston to push the ring down 1/2 inch and check. Doubt they are .012.
Old Jun 28, 2009 | 05:32 PM
vinuneuro's Avatar
Huh..how do you pre-gap rings.
Old Jun 28, 2009 | 05:35 PM
mar778c's Avatar
Community Builder
Community Influencer
Wiseco recommends
Top ring 0.005Xbore
Second ring 0.0055Xbore
See link below
http://www.wiseco.com/Catalogs/Sport...ccessories.pdf
Old Jun 28, 2009 | 05:37 PM
mar778c's Avatar
Community Builder
Follow this instruction.
Like Don said make sure the ring is seated properly.
Old Jun 28, 2009 | 05:46 PM
vinuneuro's Avatar
Ring gap is dependent on bore size. Saying that they're "pre-gapped" suggests that they come gapped 'correctly' from the manufacturer.
Old Jun 28, 2009 | 06:20 PM
mar778c's Avatar
Community Builder
No, that pre-gap is based upon a single application. Look at the pdf in the link I posted for the OP. There are 5 different gaps/bore sizes. How can you pre-gap something when you don't know the application?
Old Jun 28, 2009 | 07:06 PM
PyroProblem's Avatar
You should still check the ring gap...measure twice and cut once.
Old Jun 29, 2009 | 06:22 PM
thanks for the help guys. I called wiseco today and they gave me the correct ring gap to run at 20lbs of boost.
.017-.019 for top compression rings and .019 - .021 bottom compression rings
Rootie524
Jul 11, 2011 07:57 PM
Hybrid96EK
Apr 20, 2010 09:18 AM
Muckman
Feb 23, 2007 11:04 PM
MatHadder
Nov 19, 2006 11:04 AM
MrCrx
Jun 17, 2003 09:08 AM
