Integra shifter fit on 99-00 Si? Difference in throw/height?
Old Jun 28, 2009 | 12:35 AM
NACvicSi's Avatar
Default Integra shifter fit on 99-00 Si? Difference in throw/height?
So apparently (from what I read) the ITR and reglar Teg shifters are the same, except the ITR is polished from the factory.
So my question is will the Integra shifter bolt right in a 99-00 Si? I know they are wider than a regular Civic shifter, but no clue about Si. Also what's the height/throw difference between a Si and teg shifter?
Old Jun 28, 2009 | 04:41 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: ITR shifter fit on 99-00 Si?
ITR and GSR's have the same shifter. I have one in my 96 civic hatch, best shifter out there to swap in imo
The are positioned so well, shorter throw, and bolt right in.
Old Jun 28, 2009 | 08:31 PM
NACvicSi's Avatar
Default Re: Integra shifter fit on 99-00 Si? Difference in throw/height?
I don't see how they bolt right in a regular Civic seeing as how the Integra shifter is wider.
Old Jun 28, 2009 | 08:36 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
They do not bolt in. The bottom fulcrum point of the Integra shifter is wider.
You can just cut it. Easy fix. The throw feels much nicer. The positioning is a lot nicer as well.
Measure the part of your shift linkage where the shifter bolts in. Mark the shifter to see how much you should cut.
Cut it with a grinder/cut off wheel.
Or buy a DC linkage.
Old Jun 28, 2009 | 08:45 PM
NACvicSi's Avatar
Does this apply to a 99-00 Si seeing as they are B series also? The D series Civic shifter is 25.4mm wide whereas the Integra is 35.4mm wide. I just need to find out the width of a 99-00 Si shifter. Anyone have one to measure?
Old Jun 28, 2009 | 08:52 PM
B serious's Avatar
the 99-00 civic Si shifters are the same as all the other civic shifters. Narrow.
I own a 99-00 Si now. It has a short throw on it. It came off my friend's EX.
I've owned a 99 hatch with a B16 swap, 99-00 Si linkage, and ITR shifter. I had the cut the shifter.
I've owned a 99 GSR. The shifter was wider at the bottom.
Old Jun 28, 2009 | 08:59 PM
NACvicSi's Avatar
Yeah I knew the Tegs were wider for sure, just unsure of length of Si since it was B series. Thanks for the help
Old Jun 28, 2009 | 09:02 PM
NACvicSi's Avatar
I'm also debating going with OEM or energy suspension bushings. Any real gain over OEM?
Old Jun 29, 2009 | 11:18 AM
B serious's Avatar
The energy ones feel a bit nicer. They're only $14...so...why not?
Most of the slop comes from the linkage itself being aged. New linkages feel much nicer that used ones even with polyurethaen bushings.
mangogsr
Aug 28, 2013 07:36 AM
KUMAR
Feb 6, 2009 06:19 PM
Cheez-It
Oct 7, 2008 07:38 AM
blackjdmEKcivic
Jan 3, 2005 09:13 PM
jweezy225
Jul 22, 2004 04:24 AM
