what oil to use with forged pistons
Old Jun 27, 2009 | 11:37 PM
vtecsi00's Avatar
Icon6 what oil to use with forged pistons
I have a b16a2 that is stroked with cp pistons. I have heard either from this site or from another that i shouldn't use 5w-30 anymore and that i should use 10w-30 or 10w-40 can't remember which one. Could someone please explain to me why. Thank You....
Old Jun 28, 2009 | 05:43 PM
vtecsi00's Avatar
Icon6 Re: what oil to use with forged pistons
bump it up please
Old Jun 28, 2009 | 05:51 PM
GhostAccord's Avatar
Default Re: what oil to use with forged pistons
I didn't think new pistons really had any factor for the weight of oil you use. I was always under the assumption that bearing clearances and operating temps were the major factor when considering oil weight. Therefore, unless you changed your bearing clearances, I would figure using the same weight oil you were using before would be good. I could be wrong though.......
Old Jun 28, 2009 | 06:25 PM
1.5Slowmatic's Avatar
^^^ that was gonna be my answer. depends on your bering clearances and p2w
Old Jun 30, 2009 | 07:52 AM
vtecsi00's Avatar
some one had made that comment. So i was wondering if it was true. I did ruun my car for a month and did notice that it did burn oil a little quicker than normal. That is why i made this thread to see if i could get a definate answer before i start buying royal purple on my new build.
Old Jun 30, 2009 | 11:03 AM
busafantic's Avatar
I would prefer using synthetic.
Old Jun 30, 2009 | 01:03 PM
if you know your clearances that would help alot. If they are on the looser side try some 10w-30 and see if the smoking clears up but i would expect smoking if your still breaking in
Old Jun 30, 2009 | 05:51 PM
vtecsi00's Avatar
no smoking. its a tight fit. i will try to find the piston sheet i have in the garage.
Old Jul 1, 2009 | 05:46 AM
No smoke but you stated above that you noticed it was burning oil at a quicker rate than normal? Where is it burning if there is no smoke? Do you have an oil leak somewhere?
As for the clearances, the piston sheet will only tell you the suggested clearance. Only the person who installed the pistons and measured the installed clearances will know the exact measurements.
Did you get a spec sheet from the engine builder? or Did you install the pistons blind with no installed measurements taken?
Old Jul 1, 2009 | 04:16 PM
2001B18C1GS-R's Avatar
i run 5w-30 torco sr-1
Old Jul 2, 2009 | 10:43 AM
vtecsi00's Avatar
builder installed them. so i don't no. It just seems that i am changing my oil more frequently than normal. No oil leaks anymore. Last oil leak was the dizzy.
Old Jul 2, 2009 | 02:36 PM
96halx's Avatar
how much oil loss are you talking about? Not sure how accurate this info is, but I did read it somewhere that had some authority (can't remember where though): If your using forged pistons, they usually run a little loose on the clearances (or a little tighter, depending on silicon content) at startup so they can expand with heat and wind up with proper clearances. Therefore, it may have looser tolerances at startup, so the oil is being lost at startup until the piston gets to operating temperature.
Old Jul 2, 2009 | 07:25 PM
Wouldn't proper piston ring end gap & ring seating also come into play when it comes to oil consumption? I'm not 100% but I don't think the piston ring clearances are as loose as the pistons at start up.
Old Jul 2, 2009 | 09:24 PM
vtecsi00's Avatar
that is what i heard. Not sure how accurate. But in my case that might be my issue... But i remember something to the effect of using a different weight of oil to deal with the issue. Not sure if that is true or not????
Old Jul 3, 2009 | 02:05 AM
According to this write-up you should be using 10w40
Originally Posted by worldsbestoil.ca
Although a vehicle that is recommended to use a 30 weight oil can also use a 40 weight oil, it is usually not needed. You will gain absolutely no benefit from using a thicker viscosity oil if it is not needed. The only time we recommend a 40 weight oil to a customer in a passenger car or light truck application is if the vehicle's engine is excessively worn and consumes oil at a higher than normal rate or if the vehicle is being used for very severe duty, high load, high temperature applications.
Here is a link to the rest of the write up. Which oil do I use?"
Old Jul 3, 2009 | 09:52 AM
96halx's Avatar
Yea, I'd say try 5w40 (if they make it), or just jump to 10w40, might solve the problem. Cheap attempt anyway, so if it doesn't work, you won't be out big money. Hope it works out for ya.
Old Jul 3, 2009 | 06:08 PM
vtecsi00's Avatar
[QUOTE=GhostAccord;39120589]According to this write-up you should be using 10w40
Here is a link to the rest of the write up. Which oil do I use?"[/QUOTE
I have a motor built from the ground up. everything is new. its been bored and honed. So i quess i am still at a lost....
Old Jul 3, 2009 | 06:49 PM
96halx's Avatar
head rebuilt too? maybe seals in there? How did you break the engine in?
Old Jul 4, 2009 | 02:28 AM
So what is your question here? Are you trying to figure out what weight oil to use or why a newly built motor is burning oil?
One of your questions was why do you need to use it. The answer might be one of the following;
1. Improper piston ring end gaps
2. Improper positioning of the ring gaps (inline)
3. Leaking valve seal(s)
4. Engine not fully broken in / Piston rings not sealing against the cylinder wall.
How many miles on this engine? Have you done any sort of engine break in procedure?
Old Jul 4, 2009 | 02:00 PM
vtecsi00's Avatar
engine has 1000 miles on motor. was properly broken in. Just trying ti figure out what would cause the situation and have a sense of idea of what motor oil i should run...
Head is totally rebuuilt as well only thing stock are the rocker arms..
shandonwall
13
Apr 27, 2009 09:13 PM
frankenstienEk
Sep 8, 2007 08:56 AM
The Weather Man
Sep 21, 2005 06:17 AM
civiwhip
Jun 18, 2005 11:21 AM
StinkyTofu
Apr 9, 2002 10:47 PM
