Radius rod nut torque spec?? (6th gen)
Old Jun 27, 2009 | 02:07 PM
Nathan007's Avatar
Icon2 Radius rod nut torque spec?? (6th gen)
Hey!
Anyone knows whats the front radius rod nut torque spec??
i know the radius rod-to-LCA is 119lb/ft but whats the spec for the nut (near the radiator)?
Thanks!
Old Jun 27, 2009 | 02:13 PM
GhostAccord's Avatar
Default Re: Radius rod nut torque spec?? (6th gen)
They are self locking nuts so using new ones is recommended. They are torqued to 32 lbf-ft (4.4 kgf-m / 43N-m)
You might want to double check your specs for the two bolts that connect the RA to the LCA. The shop manual has them at 76 lbf-ft (10.5 kgf-m / 103 N-m)
Old Jun 27, 2009 | 03:19 PM
Nathan007's Avatar
alright thanks!
is there a special way to install it since i replaced the bushings, to make sure they are correctly sitting?
Old Jun 27, 2009 | 05:36 PM
Give all your bushings a light coat of silicon grease before you install them.
Old Jun 28, 2009 | 09:21 AM
nysdriver's Avatar
Also make sure to torque them *after* you put the car on the ground so that your bushings don't end up sort of twisted.
powertoweight
Apr 9, 2016 04:17 PM
N/A ALL DAY
Engine Management and Tuning
Apr 8, 2012 10:10 AM
Hunter
Feb 17, 2011 06:31 PM
jacob1217
Aug 23, 2007 05:05 PM
SupaFly_Honda
Aug 11, 2004 07:09 PM
