wheel bearing replacement job..
How much a job like this,
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-install-wheel-bearings-lower-ball-joints-pic-intensive-1567042/ will go for? Cuz I got a quote from a local shop and they charge me $160 to replace the wheel bearing. Is this a good price?
Is that parts and labor? OEM bearing?If that is with an oem bearing and labor, that's pretty cheap.
I replaced both of mine a few weeks back and although it was pretty easy to remove the hub, you have to get the old bearings pressed out and the new pressed in. Luckily, i found a guy i knew that did it for free, but most places were quoting $75-100 just to do the press work.
bsmith100
Apr 12, 2010 08:05 AM
