I turned so hard mI-VTEC shut off...
Old Jun 27, 2009 | 01:27 PM
supercivicstack's Avatar
Icon3 I turned so hard mI-VTEC shut off...
It was crazy! Over took a legit DC2 ITR on a hairpin... until that happen. Anyways I might be comming up on a K20A ITR motor comming out of some shop in canada. This is what it comes with: complete engine, Exhaust manifold, Pullys, AC compressor, Coil pack, Alternator, fuel rail, All brackets an sensors, intake manifold, power steering pump, 6speed lsd tranny, an injectors. I think wiring harness an ECU too. Is there anything else i need when i swap this baby in? If it doesn't come with the wiring harness could i use my a3 harness?
Old Jun 27, 2009 | 01:29 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: I turned so hard mI-VTEC shut off...
you can use anything from yours really. So you'll be fine
Old Jun 27, 2009 | 04:14 PM
hawaiiancb74's Avatar
what does this have to do with your i vtec turning off?
Old Jun 27, 2009 | 05:01 PM
Ha ha nothing I just thought I'd share that.
Old Jun 27, 2009 | 06:30 PM
tweek_boii's Avatar
hmmm.
Old Jun 27, 2009 | 08:09 PM
i was gona say it sounds like u need to install baffles
Old Jun 27, 2009 | 10:07 PM
DaveSi677's Avatar
it sounds like you need to slow the **** down!
Old Jun 28, 2009 | 10:41 AM
What is baffles?
Old Jun 28, 2009 | 02:21 PM
DC5_lov3r's Avatar
wtf
Old Jun 28, 2009 | 02:27 PM
Originally Posted by supercivicstack
What is baffles?
http://www.rsx-tuners.com/products.p...oil_pan_baffle
and many other designs as well, it keeps the oil from going up the timing case, and leaving the pick up dry and creating a loss of oil pressure.. which can turn off your vtec, as well as implode your motor if held at high rpms.
Old Jun 29, 2009 | 04:54 AM
turboteg2nv's Avatar
^^ winNar
Old Jun 29, 2009 | 06:02 AM
josh's ep3's Avatar
Function > Form
Oh yeah, well I made some chicken on Staurday so good, make you wanna slap yo' mama!!
Old Jul 3, 2009 | 03:47 PM
tweek_boii's Avatar
LMAO !!!
Old Jul 3, 2009 | 04:02 PM
Targa250R's Avatar
be professional
If VTEC is cutting out mid-corner, then you're losing a large amount of oil pressure due either to low oil level, or sustained g forces causing all of the oil to pool away from the pump pick-up. I tend to believe the former.
I suggest you check your oil and add as needed before you blow it up or bend valves. Remember that the timing chain tensioner runs on oil pressure.
Old Jul 4, 2009 | 05:46 AM
Ohhh cool dudes an dudetts thanks for the help.
Frozen E
Apr 27, 2006 12:13 PM
vr6chris
Welding / Fabrication
Mar 16, 2005 01:47 PM
Tomakit
Dec 10, 2001 07:37 PM
