Driver Side Floor Mat Hook System Question
Old Jun 26, 2009 | 04:21 PM
Ultraspeed DC2's Avatar
Default Driver Side Floor Mat Hook System Question
Information you might want to know before I ask my question:
-1998 USDM ITR
-I'm the 2nd owner, my cousin is the original
-Before I bought the car some items were stolen along with the floor mats
-I'm currently using those red "jdm style" ITR floor mats from eBay because I had nothing at all.
The question:
I'm tired of the mat bunching up at the pedals leaving me to always pull it back. I noticed other Integras had a hook that goes throough a hole in the floor mat to prevent it from moving. Thinking that mine was stolen along with everything else, I picked one up from a 98 GSR with the included screw. I went home and tried putting it on but couldn't find the hole (that's what I said). Did the 98 ITR not come with this setup? Is there an extra part I need to get this thing working? I don't want to put a self tapping screw in there to make a future rust spot.
Old Jun 26, 2009 | 04:58 PM
r'trukin's Avatar
Default Re: Driver Side Floor Mat Hook System Question
velcro
SlapSmak's Avatar
R's dont have the hole for the mats.
Old Jun 26, 2009 | 06:17 PM
some dude is selling some black ones with holes in it. maybe from 00-01itr?
Old Jun 26, 2009 | 06:33 PM
SlapSmak's Avatar
I have had both mats, OEM have no holes. Also, there is no retainer in the OEM carpeting for a clip
Old Jun 26, 2009 | 08:59 PM
330R's Avatar
I think the floor mat anchor did not appear until 2000 for the Integra. Here's the instructions.
parts list
83605-S30-A00 Holder, Floor Mat
90662-SB2-003 Grommet, Screw
93904-45320 Screw, Tap 5x16
Old Jun 26, 2009 | 11:21 PM
4DRDB8GSR's Avatar
FYI...
My BNIB '01 oem mats from the dealership came with the hole for the anchor.
And my '01 ItR came with the anchor and slit in the carpet oem.
Old Jun 26, 2009 | 11:25 PM
BlueIntegraBoy's Avatar
My 98 has the hole. You need to lift the flap in the carpet, after you finish cutting a slit. I put in EDM mats with the supplied anchor.
Old Jun 27, 2009 | 02:48 AM
IN VTEC's Avatar
All of the '94-'01 Integra's have the hole for the stay. You just have to get the right floor mat. I used a plastic stay with more of a hook from a '01 to '05 Civic instead of the metal stump that requires a grommet and screw.
Old Jun 27, 2009 | 04:49 AM
parts list
Thanks, exactly what I was looking for. Looks like I'm just missing the plastic thing. I did see the precut carpet area.
Old Jun 27, 2009 | 05:49 AM
nsxtasy's Avatar
H-T Order of Merit
My '94 GS-R doesn't have the hole in the floor mat, or the anchor pin.
I'm not sure what year it was started, but it wasn't '94.
Old Jun 27, 2009 | 09:02 AM
wildoutwhitegsr's Avatar
My 94GSR came with the anchor, pin & floor mat with hole
Must be a dealer thing
Old Jun 27, 2009 | 11:48 AM
nsxtasy's Avatar
H-T Order of Merit
If you look up the parts in the Acura parts catalog, those three part numbers above are listed only for the 2001 Integra, and not for any earlier year. (The way the parts catalog works, the same diagram is used for all years, but only the parts numbers pertaining to the particular year are listed below the diagram.)
Of course, you can buy them and install them in any year Integra.
Old Jun 28, 2009 | 04:08 PM
IN VTEC's Avatar
I meant the chasis.
Old Jun 28, 2009 | 05:43 PM
SlapSmak's Avatar
In my 2000R I had the checkerboard mats and I have the same in my 98, I stand corrected if there is a cut flap,insert metal tab mounting system...
Old Jul 12, 2011 | 01:57 PM
Quaddipsea's Avatar
All those looking to do a new installation should try Honda part 08P14-S84-100R1. This part is metal, not plastic, and retails for under $7. It's identical to the high quality rug hook installed in ITRs.
Old Jul 13, 2011 | 04:20 AM
CraterGrillo's Avatar
So for my '98 itr there's already a square hole in the body (instruction #4)? This has been bothering me for quite a while.
Old Jul 13, 2011 | 05:42 AM
Yes. The carpet even has a flap over the square hole that you just lift up to install the hook.
Old Jul 13, 2011 | 05:44 AM
That's awesome. I'll order the parts today! Thanks thanks thanks!
Old Jul 13, 2011 | 05:50 AM
Just ordered the parts. Ordered extra grommet and screws in case I goof it up - came to a whopping $6. WOW. This'll be the cheapest fix I've EVER made to my type-r.
Old Jul 18, 2011 | 08:58 AM
Quaddipsea's Avatar
Not only does your R have a square hole on the driver's side, it has an IDENTICAL hole on the passenger side as well. There is no carpet cutout like the driver's side, but you can find it with an awl or other sharp tool. Then you can hook the mats on both sides - a very slick solution.
Old Jul 18, 2011 | 09:01 AM
I installed it this weekend. Took all of about 5 minutes and now the mat STAYS PUT!!!
I can't believe I've been trying to figure out how to jury rig this for months when there was already a solution!
And it only cost me about $6 for the parts (AND I got spares in case I screwed up).
HIGHLY recommended for anyone who has one of the newer mats with the hole (since those mats don't stay put on their own like the original 1998 mats which were heavier).
Steve
CokeZero
Oct 20, 2014 09:03 AM
helldriver88
Mar 11, 2009 08:53 AM
niceguysfinishlast
Mar 27, 2008 05:05 PM
98DC2-ITR
Feb 4, 2004 06:20 PM
yee SERIOUS
Nov 24, 2003 02:05 PM
