Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
View Poll Results: What to do with wheels?
Swap 912s to Motegi MR7s
8.33%
Put new tires on MR7s
8.33%
Get replacement LS Mesh wheel
16.67%
Use LS Mesh wheels as is
66.67%
Voters: 12. You may not vote on this poll
Is this wheel safe for HPDE?
Old Jun 26, 2009 | 02:42 PM
Ghetto Civic HX's Avatar
I love to drive
Icon2 Is this wheel safe for HPDE?
I'm getting my car ready for my first HPDE in October. Right now my car has Falken Ziex 912s on LS Mesh wheels. One of the wheels is pretty gnarled on the lip. It holds air on the street, but will it be okay, and pass inspection, for a HPDE?
I do have an old set of 15x6.5 Motegi MR7s laying around. Should I swap the tires onto those or look for a replacement wheel?
Also, the 912 is an all-season tire, should I just keep these for DD or put something like RT-615s on the MR7s?
Old Jun 26, 2009 | 02:48 PM
jdm civic 2000's Avatar
Default Re: Is this wheel safe for HPDE?
Should be fine, just keep an eye on it from time to time.
Old Jun 26, 2009 | 03:32 PM
ALLxMOTOR EG's Avatar
Vietnamese!
^^ What he said.
Old Jun 26, 2009 | 03:48 PM
dirty19's Avatar
Ridin Dirty in Cali
tell me it was your girlfriend who bashes curbs like that?
As long as it holds air you should be ok.
Check it after every run.
Dont go spending money yet.
Your learning...
Old Jun 26, 2009 | 03:56 PM
Lo-Buck EF's Avatar
yea, those will be fine.
Old Jun 26, 2009 | 03:58 PM
I love to drive
Actually I bought those used like that. At the time a needed wheels ASAP and they were cheap. Though I have had my run-ins with curbs
But would it still be safer to put my existing tire on the other wheels so I don't have to worry about it?
Old Jun 26, 2009 | 05:40 PM
nsxtasy's Avatar
H-T Order of Merit
Yup. The damage is on the outside of the lip, beyond the area of the wheel that holds the bead (the inside edge of the tire). It should be fine.
If you care about how your mesh wheels look, you could take the damaged wheel to a professional wheel repair shop, and they can fix it. However, they typically charge $100-125 for doing so, and you might be better off just picking up another used set.
I recommend doing your first few HPDE events using whatever tires you're normally using on the street. You won't be using your tires' full capabilities anyway. Besides, less sticky tires are easier to learn from because they give lots of audible warning before they lose all traction.
Once you've done, say, half a dozen events, then you'll have a better idea of what changes you want to make to your setup (and they may be entirely different from what you think you want to change now).
Have fun.
Old Jun 26, 2009 | 09:48 PM
I love to drive
Thank you all for your advice!
I'm not concerned how my wheels look, I just wanted to make sure they were safe.
Old Jun 27, 2009 | 01:09 AM
tazeat's Avatar
They look fine to me, but I'm not expert Like said above, the what looks to be minor dents are well outside of where the bead seats.
Old Jun 27, 2009 | 06:22 AM
kaiba's Avatar
As long as it will hold air and doesn't vibrate/shake at high speed then your good to go.
Old Jul 1, 2009 | 05:24 PM
raffaelli's Avatar
Safe or not, that gonna be on your mind while you are loading in turn? Piece of mind is worth more than you might think.
Old Jul 3, 2009 | 11:14 AM
mrlegoman's Avatar
As said before, your ok. Dents are ok. Cracks are bad.
Get them re-balanced if they haven't already been.
Don't get so worked up over them that you lose focus on the track.
There are some pics of my old wheels in this thread:
https://honda-tech.com/forums/showpo...5&postcount=42
Those are 'bad'.....
RED_October94LS
Nov 19, 2009 07:22 PM
hughesl
Apr 14, 2007 06:58 PM
PA MATT
Nov 5, 2006 06:34 PM
Smoothy
Jul 2, 2003 12:45 PM
NunRacer
Jul 5, 2002 05:29 PM
