DIY - 1994-2001 Acura Integra - Outer Tie Rod End *PICS**
While I had my wheels out in preparation of replacing the CV Axles I noticed one of my tie rod end bushing was bad. I figured hell since they're so cheap & easy, why not just replace both of them for brand new ones.
Tools required:
Pickle fork
17mm Socket & ratchet
2 adjustable wrenches
BFH (Big freaking hammer)
Pull the cotter pin off the castle nut.
Use the 17mm socket & remove the castle nut. After that, use the picket fork to wedge it between the ball joint & hammer it to loosen it up.
Place the 2 adjustable wrenches as shown and turn the indicated wrench clockwise to loosen & remove the rod.:mamoru:
Install the new outer tie rod end in reverse order (maybe without the pickle fork step >
Tools required:
Pickle fork
kroze
Jan 2, 2006 06:20 PM
