DIY - 1995 Integra Rear speakers replacement **PICS**
Old Jun 26, 2009 | 09:27 AM
kroze's Avatar
Default DIY - 1995 Integra Rear speakers replacement **PICS**
Tools needed.
- 10mm deep socket, extension, & ratchet.
- Phillips screwdriver
- Flat head screwdriver
- Plier
- Interior clips removal tool
Start by removing these clips with the body panel removal tool.
Use the plier & pull this clip off.
Now release the seat at an angle & push toward the arrow indicated to get the seat out
Next remove this 10mm bolt
Lift the back end straight up like so and wiggle the seat out.
Here's a picture of the seat's hook for reference.
Open the rear strut cover & remove the 10mm bolt. And use the phillip screwdriver & remove the plastic screw.
Remove this 10mm bolt
Remove these plastic/metal screw with phillips screwdriver
Remove the speaker cover & remove this screw.
Unplug this hatch light & Now you're pretty much done, start pulling the panels out.
Remove your stock speakers & install your new 6.5" speaker of choice.
broncoman74
Aug 11, 2004 07:33 PM
darkplague
Jun 9, 2004 11:54 AM
sunsetway
Jun 7, 2003 11:19 AM
151 Proof
Apr 2, 2003 09:26 AM
Kyo Babic
Mar 24, 2003 09:47 PM
