Transmission & Drivetrain Gearboxes, Differentials, Clutches
Wheels spin while in neutral
Old Jun 26, 2009 | 12:37 AM
beanbag's Avatar
Default Wheels spin while in neutral
So the other day I was changing my oil and had the front of my car on jackstands. When I started the car, I noticed that the front wheels were spinning, even while the transmission was in neutral. But once I stepped on the brakes and let go, the remaining sticking from the calipers kept the wheels from moving. Is this normal or no?
Old Jun 26, 2009 | 04:43 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Wheels spin while in neutral
normal
Old Jun 27, 2009 | 05:34 AM
HYREV2NR's Avatar
The pressure plate and flywheel are feather touching the clutch disc is why.
Old Jun 27, 2009 | 07:28 AM
DEIVIONCRX's Avatar
Normal, the transmission gears are always meshed, just the syncros are not engaged. The input shaft gears moving, pushes the fluid, and the fluid actualy can turn the output gears, and with no resistance on the wheels and differential they can turn. Like you said just enough drag on the brake pads was enough to stop them.
If its up in the air and he is out of the car, the clutch is engaged.
Old Jun 28, 2009 | 04:51 PM
HYREV2NR's Avatar
Think I got this thread mixed up with one I read earlier where the clutch was disengaged. Oops-
loosestool
17
Oct 9, 2006 06:34 PM
red01s2k
Honda S2000
Jul 7, 2006 04:58 PM
batboyvaj
Mar 28, 2005 06:46 PM
egrichie
Nov 22, 2004 10:48 AM
Nextelbuddy
Feb 16, 2004 07:23 PM
