Clutch Pedal started to squeak…
Old Jun 25, 2009 | 09:32 PM
FOMULA91's Avatar
Default Clutch Pedal started to squeak…
It wasn’t bad but start noticing that every time I clutch in, it squeaks both time when I press in and release. Is this telling me that the clutch cable is wearing off or is it the pedal assembly?
Forgot to mention but I have a 89 HF with B16 cable transmission...
Old Jun 25, 2009 | 09:45 PM
jdmkid37's Avatar
Default Re: Clutch Pedal started to squeak…
mine squeaks too. I have over 200,000 on the clutch however haven't noticed anything out of the ordinary while shifting no grinds or sticking of the sort.
Old Jun 25, 2009 | 10:32 PM
BiG ChOr!Zo's Avatar
wd-40
Old Jun 25, 2009 | 11:54 PM
FOMULA91's Avatar
Originally Posted by BiG ChOr!Zo
wd-40
LOL for real??
I search and people mentioning its the spring on the pedal assemble which might be right and others said its the throwout bearing inside the transmission but I doubt that since the noise is coming from the pedal....
Old Jun 26, 2009 | 01:32 PM
FOMULA91's Avatar
So, lubricating the spring on the clutch assembly is one symptom.. Anyone else?
Old Jun 26, 2009 | 01:59 PM
jdm27ef's Avatar
yeah lol just lubricate the springs and your good to go hahah
Old Jun 26, 2009 | 06:09 PM
Coltmorris's Avatar
My pedal squeaks very loudly when its pressed and when it goes back up. I got a brand new clutch, brand new clutch cable, new flywheel, tb, hell I have a new trans in there haha. I sprayed the pedal assy. with not only WD40, but I tried some white lithium grease as well. It STILL squeaks just as loudly as ever. My theory is if I were to replace my pedal assy., it would solve the problem.
Old Jun 26, 2009 | 06:51 PM
go to your local railroad tracks or railroad yard and scoop up some crater grease left by the tracks and put some on your pedal assembly and spring...that sob will grease it up perfect and will never come off...!!!
Old Jun 26, 2009 | 07:12 PM
FOMULA91's Avatar
Yeah I didn't want to start replacing stuff which aren't bad.... I will lubricate and see if the noise goes away, if not I'll probably replace the spring...
Old Jun 26, 2009 | 07:17 PM
sleepingciv's Avatar
wd40 pb blaster marvel oil and spray lube will work. marvel is not spray but works very well
Old Jun 27, 2009 | 08:02 PM
akshn1's Avatar
check ur clutch cable..it might worn or stretched....same **** happen to mine...my clutch pedal snapped..lol..so i just replaced the whole pedal assembly and clutch cable!!!!
Old Jun 28, 2009 | 04:52 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Mine was making a light squeak... WD-40... it's been 3k miles, no return... Just get under there with a few towels so you don't stain your carpet/mats.
Old Jun 28, 2009 | 08:00 AM
clumsyfool's Avatar
its the pedal assembly. mine squeaked fo bout 2 months before it broke..
i replaced it in dec. i think and my new one is squeaking again so im gonna switch my dual diaphram pressure plate to a stock one so i dont have this problem again..
Old Jun 28, 2009 | 12:16 PM
johnnyonth3spot's Avatar
mine squeaked got a new oem cable no squeak keep in mind I tried all of the above with only temporary success
Old Jun 28, 2009 | 06:34 PM
verycleanhatch's Avatar
i think this would apply to ur situation. i use to have a squeak only when i depressed my clutch pedal. i sprayed some lithium grease inside the boot which was located left of the slave cylinder.
There is like a ball and joint type of thing that squeaks i guess when it loses it's grease.
Old Jun 30, 2009 | 10:40 PM
89sihatchls's Avatar
X2
Old Jul 16, 2009 | 11:53 PM
FOMULA91's Avatar
OK it was my cable.... I replce it and no more noise
Old Jul 17, 2009 | 09:26 AM
hatchet_honda's Avatar
ehhhh with my catback exhaust and music goin i aint hearin no squeaks fooo
Old Jul 17, 2009 | 10:56 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Haha cool.
bgm1958
Mar 12, 2012 10:34 AM
95ACCLUDE
Jan 29, 2009 04:35 PM
d16dcoe45
Nov 10, 2006 01:06 PM
groundedcivic91
Jul 15, 2006 09:59 PM
Quik89Si
Mar 12, 2002 07:07 PM
