b20 mates with b18
Old Jun 25, 2009 | 05:37 PM
VTEC_PRODUCTION's Avatar
Default b20 mates with b18
i have a b18b thats no longer good block wise. my question is if i can get a b20 block from a crv and put my b18b head on it and use my original wiring harness with the b20 block and my ecu. is it plug and play? will it work? i have a 94 integra ls, head, wiring harness, and ecu.
Old Jun 25, 2009 | 06:13 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Default Re: b20 mates with b18
Yes it will work.
It will also bump up the compression.
Old Jun 26, 2009 | 04:48 AM
i just want to be sure. thanks. so the block will work even though it comes from an obd2 vehicle into my obd1 and using my ecu?
Old Jun 26, 2009 | 04:56 AM
be18see1's Avatar
Yeah it will work fine. Your obd1 harness should drop right onto it.
Old Jun 26, 2009 | 05:10 AM
cool. how will this hybrid increase compression though? both the b18 and b20 have the same 9.2:1 compression right? it also seems that the b20 makes less power and has a lower redline of almost a 1500 rpm difference. whats the deal?
Old Jun 26, 2009 | 05:57 AM
xintegridyx's Avatar
New User
yea it works wonders, i have the b20 block with the gsr head and tran in my integ
Old Jun 26, 2009 | 07:46 AM
be18see1's Avatar
He's not using a vtec head..right?
Look up the combustion chamber volume for the heads or use the c-speed compression calculator to determine your CR. The LS and b20 blocks are practically identical besides the bore, so I don't know why the redline would be different. I built a b20vtec that revs to 8k and I had no problems.
latinf86
Jun 25, 2006 11:45 PM
TJ99si
Sep 7, 2005 04:44 PM
PrOjEcTpImPcIvIc
Nov 12, 2003 07:08 AM
88civicHB703
Jul 8, 2003 06:45 PM
willywood16
Mar 20, 2003 08:30 PM
