Transmission & Drivetrain Gearboxes, Differentials, Clutches
Flywheel question
Old Jun 25, 2009 | 04:00 PM
neuvtec's Avatar
Default Flywheel question
i am going to purchase a new lightweight flywheel 7.5lbs, 8lbs, etc... and i am trying to find out the best one to get for my ls motor with a gsr tranny. i am hearing that you will loose torque the lighter you go. is this true? any information is helpful.
thanks
Old Jun 27, 2009 | 05:38 AM
HYREV2NR's Avatar
Default Re: Flywheel question
Not trying to be a jerk but do try using the search function because there are endless threads on flywheels. Personally, I like them but it does take some getting use to. Good luck.
Old Jun 27, 2009 | 07:04 PM
neuvtec's Avatar
Thanks for the info. My bad, i haven't used honda tech in a while. Just recently started getting back on the forum again.
Old Jun 30, 2009 | 08:20 AM
HYREV2NR's Avatar
Welcome back. Getting use to the new format can be quite a pain at times. My dial up connection doesn't like it at all.
oneslodx
May 4, 2004 08:36 AM
MugenB16A2
Nov 12, 2003 08:57 PM
Kusai.Nihonjin.Desu
Aug 26, 2003 09:01 PM
integranator
Jul 25, 2002 05:25 PM
96tegsr
Jun 2, 2002 01:43 PM
