Changing transmission fluid? 2003 3.2TL
What does it take to change the tranny fluid? The car has 83K miles on it and now should be a good time. Is there a tranny filter? Do I just a bolt on the bottom of the tranny and let it drain and than refill through the dipstick hole? I've never messed with this car.
Yeah old thread I know but you do a 3x3 drain and fill. Thats drain 3 qts, fill it back up, and repeat for a total of 3 times. There is alot more info on acurazine.com.
BTW I just did this on my 02 TL-S and it actually improved shifting dramatically. Only use Honda/Acura ATF-Z1 fluid.
drain plug on the bottom,refill bolt on top just unbolt the bolt size 17mm i think. i use funel with a tube on the bottom to fill my trany fluid on my type s buy 4 bottle from the dealer should be around 3 3/4
2. drive 10 miles
3. repeat 1 and 2 two more times
jwrape
Jul 13, 2006 03:06 AM
Kyles ej1
Sep 23, 2004 04:41 PM
