Is this too close to the sidewall to patch?
Old Jun 25, 2009 | 07:15 AM
aalb1's Avatar
Default Is this too close to the sidewall to patch?
I patched it in advance but will trash it if it's too close to the edge.
Old Jun 25, 2009 | 08:50 AM
DBAl's Avatar
Default Re: Is this too close to the sidewall to patch?
It is right on the edge. I wouldn't risk it.
Old Jun 25, 2009 | 04:56 PM
tek_civic's Avatar
the risk of patching a sidewall edge is really just that... PATCH..
Inside the tire patches are much more difficult to get to stick and stay on a sidewall so they are not a good idea, plugs dont work well on the real side because the rubber is too thin to really get a good and safe seal.
You really gotta use your own judgement, if theres not much rubber where your plugging, then prolly not the best idea. If theres a good amount of bite(with your hole shaper tool) then your prolly ok. I would much sooner run a risky tire on a crx or something than an suv though.
Old Jun 25, 2009 | 05:01 PM
alphalanos's Avatar
I patched one of mine that was just a little more towards the middle than yours. Its holding up. But it was incredibly hard to get the hole tool through. You should plan on getting two tires.
Old Jun 27, 2009 | 03:19 PM
laocivic's Avatar
do it..keep a spare in your car. then see how it holds up
Old Jun 28, 2009 | 02:21 PM
nsxtasy's Avatar
H-T Order of Merit
Great advice. If the tire blows out and you run off the road and smash up your car, you can just put the spare on, if you don't get injured in the accident.
The tire is damaged beyond repair. Just replace it. Tires are one area where you really don't want to risk your safety.
Old Jun 30, 2009 | 09:55 PM
vtecsi00's Avatar
the rubber manufacture association other wise none as RMA suggest that any tire that has a puncture on the shoulder area is not a safe tire to be repaired. As nsxtasy has stated get a new tire.
EvenStar
Jan 6, 2009 07:40 PM
MrXclusivE
Sep 29, 2008 11:40 AM
85ZC
Apr 23, 2008 04:56 PM
hometheaterman
Sep 4, 2007 10:33 AM
