What is a Redline and HP/TQ numbers on a 97 spec JDM B18C (typeR)?
For Redline I've heard from 8200-8400 RPM.
For HP I've heard from 195-214.
What is the true HP and redline on a 96-97 spec JDM Integta type R? I just swapped in this swap 2 weeks ago and I wanna set my tach to the proper RPM. Thanks
i think you can find the answer around here if you look but to answer your question i think they are 200hp at 8100 rpm and 134 lbs-ft at 6200 and redlines at 8400 i believe
No b-series engine came from the factory with more than a 200hp rating, and that's all the ITR engines.
I have a 97 JDM ITR swap in my car with a matching ECU and my fuel cut is 8600rpm, which as I understand it is the case for all JDM ITR engines. As I understand all USDM ITR engines have the 8400rpm redline.
JDM and USDM are practicly same motor. People may say HP is more on JDM is because they (Japan and other non US markets) run on higher octane gas, thus more HP. When you use our watered gas here in the States, HP is 190 (Stock). Redline is 8400.
I might be wrong but noone ever proved this theory wrong.
i dnt think higher octane gas is more powerful then regular gas i thought higher octane gas only eliminated knock due to high compression but as far as power gains octane has nothing to do with it. atleast thats what i thought i could be wrong
From: Howcome we park on driveways, and drive on parkways?
ive seen many places rate the JDM ITR motor at 210hp....i have the JDM ITR motor and i have the JDM cluster in my civic and the fuel cut on mine seems to be between 8500 and 9k....im never looking cause im looking straight ahead. But its right around there.
JDM was 220 based on higher octane gas, slightly different ecu mapping to take advantage of the gas, and the JDM R Header
2001 JDM Honda Integra Type-R SpecificationsChassis
Brakes F/R: ABS, vented disc/disc
Tires F-R: 215/45 ZR17
Engine
Type: Inline-4
Displacement cu in (cc): 122 (1998)
Power bhp (kW) at RPM: 220(162) / 8000
Torque lb-ft (Nm) at RPM: 152(206) / 7000
Redline at RPM: n.a.
Exterior
Length × Width × Height in: 172.6 × 67.9 × 54.5
Weight lb (kg): n.a.
Performance
Acceleration 0-62 mph s: n.a.
Top Speed mph (km/h): n.a.
Fuel Economy EPA city/highway mpg (l/100 km): n.a.
USDM is 195 HP
Engine
Type: Inline-4
Exterior
Performance
Engine
Type: Inline-4
Exterior
Performance
Every professional media publication ive come across puts the factory rating at 195 for the USDM and 197 for the JDM. A lot of people at the rumor mill perpetuate all kinds of stuff. Also consider Japan use PS for power rating. 220/152 sounds more like a DC5R and not a DC2R
^^ That sounds more like it Kidkorner, and is what I've seen pretty much everywhere reliable.
I can almost guarantee you the JDM ITR B18C engine did not put out 220hp and 152lb-ft. Like Kidkorner said, those numbers look like the K20-R not the B18C.
I think the fact that wherever you copied that list from, SlapSmak, doesn't have the curb weight, redline, or any performance figures kinda tells me that they didn't really know what they're posting.
One thing that's for sure though is that the JDM ITR engine has a slightly higher compression ratio...11.1:1 versus I think 10.6:1 or 10.8:1 (someone correct me on that).
USDM B18C5 Engine
Displacement (cc):
1797
Power (bhp@rpm):
195 @ 7,800 rpm
Torque (ft/lbs@rpm):
130 @ 7,600 rpm
Compression Ratio:
10.6:1
Bore (mm):
81
Stroke (mm):
87.2
Cam Design:
DOHC
Valve Train
VTEC
Year: JDM B18C '96-01
Valve Train: DOHC, VTEC, 16 Valve
Transmission: Hydraulic
Displacement: 1979cc
Compression: 11.0:1
HP: 200 @ 8000rpm
Torque: 134 lb-ft @ 7500rpm
Redline: 8900rpm
Corrected, heck even I have a hard time remembering these #'s
it's not 200hp it's 200ps which equates to 197 hp, these are advertised specs, we all know power differs in reality
it gets tricky because even 197hp in honda HP is actually less (in today's terms)
Notice how the S2000 from 2005 to 2006 went from 240hp to 237?
The way they measure HP in 2006 changed, they standardized with other automakers.
I'm not so sure that 8900rpm redline number is correct...I have a real 97 JDM ITR ECU and I get fuel cut right at 8600rpm.
The S2000 is making the same power in both years, it's just that the Society of Automotive Engineers (SAE) adopted a new standard in 2006 that the alternator be included when manufacturers measure the production engines power. Not all manufacturers adopted this, nor was it required.
The same could be said about the power of engine in the hot rod days. The engines then would actually produce less power then what they were advertised to if measured on modern equipment. We all know that manufacturers advertised the vehicles power and often they under estimated this underadvertised this power. But, if the engine were put on the equipment available today the equipment would show that these engines produced less power, meaning if the engine truly measure 500bhp back in 196X and then measured on todays equipment the engine would measure lower.
Holy mis-information batman. 195hp for the US and 200ps (or 197ish hp) for the JDM. Redline is at 8400 on both w/ fuel cut at 8600.
USDM is 195 HP
Engine
Type: Inline-4
Exterior
Performance
Engine
Type: Inline-4
Exterior
Performance
Should be 1797cc hense the B18C. 1.8L not 2L
