No reverse Gear
Hi all i Don't know whats happened but all of a sudden my car won't go into reverse all the other gears are fine it has done this before but after a couple of days in normaly fixes itself what do you guys recon
Honda Accord 2001 2.0l vtec (cg9) F20 engine
Cheers
Cheers
If you start the car out of gear, is it ever hard to put it in first gear? Does it ever grind? The clutch may not be releasing completely.
That generation of car didn't have some kind of a solenoid to keep you from tossing it in reverse while moving did it?
benfromthebay
Oct 19, 2016 07:28 AM
