Bogging between gears after First.
Old Jun 24, 2009 | 11:17 AM
jo7man4's Avatar
Default Bogging between gears after First.
So this morning I went out to go to school, so the motor was fairly cold I was pulling from my drive way, first gear went in fine revved fine too its when I shifted into second gear that it bogged really bad and after having it slightly floored in the beginning of second gear for like 20 seconds than it would pick up. So basically what I am feeling is kinda like in the beginning of each gear after first, it doesn't do it at all in first, fuel gets cut than it picks up again it does this every gear after 1st is it because it was cold? It idles perfect as well so it doesn't seem to be vacuum related. Any help will be appreciated I was maybe thinking my injectors were getting clogged I don't know.
Old Jun 24, 2009 | 11:29 AM
gibsanez's Avatar
Default Re: Bogging between gears after First.
Any CELs?
Old Jun 24, 2009 | 02:06 PM
jo7man4's Avatar
no cel but you know what i totally forgot my fuel gauge doesnt work so i might just need fuel ill try it out see what happens duh! brain fart
Old Jun 24, 2009 | 02:12 PM
99civicsiguy's Avatar
my 97 chevy did this when the fuel pump was slowly dying, no power at first and it would almost die, then the power would kick back in and it would go fine, until the next gear. mine would do it in first also tho. get some gas first lol
omgwtf
Nov 18, 2012 08:47 PM
Johnny_9
Feb 2, 2008 08:29 PM
Drew96EJ
Aug 21, 2004 06:22 PM
pa2play
Jul 25, 2004 01:24 PM
