swap help...
so i picked up a 88 hatchback shell, i think it was dpfi because it doesnt have a resistor box. a couple days later i found a cheap engine (d15b non-vtec), wiring harness (obd1) and a ecu (p06) so i bought it. ive been doing some reseacher and asking around and to make it work i need a obd0 to obd1 ecu conversion and a stock wiring harness from any 88-91 civic. also since my car was a dpfi what would i do to make it pgm-fi or do i not need to worry about that?
Yes you need to convert the car to obd1 to use the p06 ecu, for this you will need a ECU conversion harness as well as a distributor harness. You WILL need to find out what model it is, DX or STD and get the engine harness for the car, no other car harness will plug into it.
You will need to convert the car to MPFI which is only 4 wires and swap some, very easy, bunch of writeups in the FAQ on how to do it.
after enting my vin in this vehicle history faqs this is what came up..
any idea what model my car is?
Year: 1988 Style/Body: Hatchback 2D
Make: Honda Engine: 1.5L I4 MPI
Model: Civic Country of Assembly: Japan
http://www.autohausaz.com/honda-auto...n-numbers.html
Vin break down, don't post your vin on this site, too many people of questionable nature sadly.
cdndna
Feb 6, 2006 11:11 AM
89crx1184
12
Jul 7, 2005 01:20 AM
psychadelicfreedom
Jul 2, 2005 11:22 PM
