Help me remove this car alarm
This is a Hornet 755T. It has a two-button remote, shock
sensor, valet switch. No starter kill or anything fancy installed.
This is on a 1988 Honda Civic STD. I got the alarm around 1990 or 1991.
I am not sure which wires reconnect to what but I want this thing out.
Thanks
Thanks
find the brain and cut the wires, find the horn and cut and unbolt the horn, take fuse out and done.
You don't have to worry about the wires that are still in there just make sure you tape off ends that you cut.
If there is no starter kill or anything then you don't have a lot of wires, just find the black box (its probably behind the fuse box) and follow the wires for the siren, door switch, power, ground and lights. I wouldn't just cut the wires... that would bother me! Hell, you could just unplug the wiring harness from the box and presto, alarm removed.
I would like to be able to reconnect the wires that the alarm patched into if this is even necessary. I thought you had to cut into some wires under the dash, attach them to the alarm, then attach some of the alarms wires to the car's wires you just cut. I could be wrong. But that is in essence what I am trying to do is reconnect the original harness wires back together. I hope I am making sense.
codizz88
Audio / Security / Video
May 12, 2016 08:28 AM
XxKingZofPaki03x
Oct 19, 2004 09:49 PM
egsi32
Sep 19, 2004 10:52 AM
