Dyno Pics - Stock Motor with Bolt-ons - (dynojet with wideband O2 sensor)
Old Aug 21, 2002 | 10:10 AM
vtec.dc2's Avatar
Default Dyno Pics - Stock Motor with Bolt-ons - (dynojet with wideband O2 sensor)
honda j-spec. 4-1 header, 2.5cat&exhaust, comptech foam filter, larger injectors, f.p.r. and hondata
torque is ~ 125 at 6-7K
oustide temp. in 90's
other mod is comptech icebox - still wondering if stock air box would work better in this setup
comments, suggestions, opinios?
Old Aug 21, 2002 | 10:14 AM
Hybrid ctr's Avatar
Default Re: Dyno Pics - Stock Motor with Bolt-ons - (vtec.dc2)
A/F = 17.5??????
Old Aug 21, 2002 | 10:16 AM
JPP's Avatar
JPP
Why the larger injctors ?
Might be running a bit lean at +- 3000 rpm to 4000 rpm.
Did you do only two runs ?
Old Aug 21, 2002 | 10:18 AM
MPH's Avatar
MPH
New User
What size injectors and why? Lean as a ****.
Old Aug 21, 2002 | 10:22 AM
vtec.dc2's Avatar
Default Re: Dyno Pics - Stock Motor with Bolt-ons - (JPP)
these are recent runs, just base runs, no tuning this time
larger injectors are in mind for future modifications + stock were running at max past 8500
Old Aug 21, 2002 | 11:17 AM
sgT's Avatar
sgT
Default Re: Dyno Pics - Stock Motor with Bolt-ons - (Hybrid ctr)
A/F = 17.5??????
ignore that
Old Aug 21, 2002 | 11:18 AM
Reid's Avatar
Global Moderator
Maxxed out stock injectors on a stock motor?
Old Aug 21, 2002 | 11:27 AM
sgT's Avatar
sgT
Default Re: Dyno Pics - Stock Motor with Bolt-ons - (Reid)
Thats what honda does. They like to run 100% at higher rpm stock.
Austin's Avatar
You're running quite lean throughout the rpm band...I prefer to have it ~13.0:1, but that's me...
Austin
Old Aug 21, 2002 | 11:37 AM
RTW DC2R's Avatar
Default Re: Dyno Pics - Stock Motor with Bolt-ons - (Austin)
why is the torque going up and down so much around the midrange?
Old Aug 21, 2002 | 11:40 AM
MPH's Avatar
MPH
New User
Default Re: Dyno Pics - Stock Motor with Bolt-ons - (RTW DC2)
That's the a/f.
Old Aug 21, 2002 | 12:01 PM
RTW DC2R's Avatar
Default Re: Dyno Pics - Stock Motor with Bolt-ons - (MPH)
That's the a/f.
Can you explain how you know its the a/f and why the HP doesnt jump around as well? Thx
Ryan, who is just trying to learn.
Old Aug 21, 2002 | 12:14 PM
JPP's Avatar
JPP
The scale on the left of the graph is the HP and the scale on the right of the graph is the A/F ratio. It goes up only to 18.
The HP curve doesn't jump around or follows the A/F ratio curve because there is not a direct relation between the two values (compared to let say torque values vs hp values for exemple).
Old Aug 21, 2002 | 12:21 PM
MPH's Avatar
MPH
New User
Exactly. If he was to maybe richen the top a little he might pick up a few hp. I would richen everything just so the car wouldn't run so hot. I had my a/f look similar to this once and my Spoon oil pan heat shield thingy burn't to a crisp.
Old Aug 21, 2002 | 12:24 PM
RTW DC2R's Avatar
gotcha....i never even realized that scale on the right was the a/f range. thanks fellas
Old Aug 21, 2002 | 06:25 PM
vtec.dc2's Avatar
for some reason it made less hp when running richer, at 0.5 richer it made 3whp less across the curve
btw.. injector size is 370..
[Modified by vtec.dc2, 8:08 PM 8/21/2002]
integraRS-T
Jun 26, 2007 05:37 PM
conradb212
12
Nov 21, 2004 07:41 PM
showtymers619
Mar 28, 2004 01:48 PM
r7
Aug 20, 2003 11:11 AM
vtec.dc2
Aug 22, 2002 02:58 PM
