94 Accord - both fan motors shot
Old Jun 23, 2009 | 05:30 PM
newhondaowner29's Avatar
Default 94 Accord - both fan motors shot
My repair shop has a diagnostic tool that showed that both of my fan motors are shot. Looks like to replace them the cost of just the two genuine honda replacement motors are $300+ So what I am wondering is if there is a generic replacement that is semi reliable or gets good reviews? I understand these things have to be able to put up with a lot because of the exposure they get to the elements.
Second question how hard would it be to replace them? Would I have to take the whole goddamn radiator out??
Thanks in advance for any help you can provide!
Old Jun 23, 2009 | 06:52 PM
SpazMan's Avatar
Default Re: 94 Accord - both fan motors shot
I replaced the condenser fan in my 92 Accord a few years ago. The radiator does not come out. The fan brackets are all that come out. It's a tight squeeze. The fan motor was $50 I believe.
Ari
Old Jun 23, 2009 | 06:54 PM
djkurious's Avatar
I purchased both fans for my accord for about 80 buxs from ebay. Takes about 20 minutes to replace both and they are plug-and-play.
Old Jun 24, 2009 | 07:30 AM
How plug and play? Can you outline what you had to do? Thanks very much!
Old Jun 24, 2009 | 08:04 AM
TheMuffinMan's Avatar
He knows where you live!
Unplug both plugs
Unbolt the 3 bolts on each fan
Pull fan out, put new fan in.
It is very straight forward.
Old Jun 24, 2009 | 08:10 AM
Originally Posted by TheMuffinMan
Unplug both plugs
Sounds like it. You can do all of this with the radiator still installed in the car? Also do I have to jack up the car to get to the bottom bolts?
The problem is that I live in some fricking condos and I technically am not allowed to do car repair in my car port (there is a really nosey neighbor who watches the area like a hawk so I have to be stealthy and fast). Thanks!
Old Jun 24, 2009 | 08:17 AM
SpazMan's Avatar
If you have A/C, it will be a tight squeeze getting past those metal lines.
You didn't explain the reasons for taking your car into the mechanic - does the car overheat? Does it make scary noises? If the fans are just making noise, and still work, you can move the car a short distance and work in, say, the Autozone parking lot where you got the fan motors. That way, you can ask for a bit of quick help from the dudes who work there, if you need it.
Ari (who has done work in the Autozone parking lot)
Old Jun 24, 2009 | 08:20 AM
Yes I had to take it to the mechanic because it is overheating and as their dealer cert diagnostic tool found that both fan motors are worn out. As long as I am not in too much traffic for too long I can still drive the car it is just a bit of a risk. Blown gaskets and all that. I bought some fan motors off ebay for $75 for the pair. Did not think about the Autozone. Well maybe I can cancel the order before its too late.
Incidentally I found out today that the repair shop that diagnosed the problem charges $200+ per motor!! I told the shop I could get the honda part for $150 and could I just buy the part and maybe have them install it (not yet knowing how easy it is to replace myself) and they said they could do that but would have to charge more for labor in order to meet there overhead. So I wont be using them.
Old Jun 24, 2009 | 09:23 AM
billyrusa's Avatar
You can do it and it is not very hard.
1. Remove the Radiator Upper Bracket so that the radiator can be pulled forward to give you more space to pull the fans out.
2. Remove splash shield from the bottom of the radiator to easily remove the bottom's bolts. If do this, you need to jack the car up. You can also tried to looase the bottom bolts from top. It will be harder. But, can be done because I have done that once.
3. Disconnect the electrical connectors. Again, if you jack the car up and remove the splash shield, it will be much easier to disconnt Radiabtor Fan's motor connector.
4. Remove the Condensor fan first to give more space for removing the Radiator Fan.
5. Then, remove the Radiator fan. It is a little bit hard because the space is very narrow. But, it can be down.
Old Jun 24, 2009 | 10:50 AM
djkurious's Avatar
For that compressor line that literally sits on the condensor fan, I bent it about a inch to remove the fan.
DO NOT PAY ANYONE TO DO THIS! It is way too easy!! DIY!
If you look at some of the fans on ebay or wherever, the bottom bolts don't have to be removed, just loosened and tightened once the fans are installed. The top of the fans mounting locations is self-explanatory.
Old Jun 24, 2009 | 11:36 AM
Cool! I will give it a shot! Just waiting on the parts! Thanks for everyone's help!
Old Jun 30, 2009 | 01:50 PM
Well it appears your description was the MOST accurate of the bunch. I definitely had to take of the splash shield in order to get to two of the bottom bolts, but I found I did not have to jack up the car in order to do it. Overall it was a pita, but worth the savings!
Thanks for your help everyone! Wish I could buy you all a round!
drinion
Jul 4, 2017 12:33 PM
TinyMac
Nov 19, 2013 04:53 PM
galt88
Aug 23, 2012 02:36 PM
ant13
Aug 22, 2011 03:49 PM
diyer
Jun 6, 2008 10:53 AM
