Mustang injectors in a B16???
Old Jun 23, 2009 | 05:09 PM
DoubleEx's Avatar
Default Mustang injectors in a B16???
Will this work? IF i get the injector clips and wire them in will i be able to run these? I know they are taller and i will have to use spacers on the fuel rail to bolt them down. They are free and like 550cc
Old Jun 23, 2009 | 05:11 PM
T.Rex's Avatar
Default Re: Mustang injectors in a B16???
just get some dsm blue tops from junk yard
Old Jun 23, 2009 | 05:19 PM
lunalink's Avatar
dsm?
Old Jun 23, 2009 | 05:22 PM
DoubleEx's Avatar
mitsubishi?
Old Jun 23, 2009 | 06:36 PM
D16SiHatch's Avatar
Originally Posted by DoubleEx
mitsubishi?
yep. mitsubishi and eagle.
Old Jun 23, 2009 | 07:23 PM
DoubleEx's Avatar
i already got the mustang ones though.
Old Jun 23, 2009 | 07:50 PM
8dxhatchy8's Avatar
try it and let us know....
Old Jun 23, 2009 | 07:56 PM
beana's Avatar
check the impedance first(get a voltmeter, put it on OHMs) if they're 14.00 or higher you can use them if not you'll fry your computer unless you run a resistor box
Old Jun 23, 2009 | 08:04 PM
DoubleEx's Avatar
i have a resistor box right now.
Old Jun 23, 2009 | 08:05 PM
DoubleEx's Avatar
my injectors are yellow.
Old Jun 23, 2009 | 08:11 PM
vtechjunkie's Avatar
That is another good alternative to doing things the expensive way(or the right way). If they work then let us know. But like "beana" said, check the inpedence. You will end up spending more fixing things than it would have cost to just buy a set of good honda injectors.
Old Jun 23, 2009 | 08:13 PM
DoubleEx's Avatar
so if its over 14 then i just take resistor box out? How do i rewire it to use it w/o resistor box?
Old Jun 23, 2009 | 08:17 PM
D16SiHatch's Avatar
well of course remove the box, and then solder the 5 wires going to the box together. their are 4 red/blk wires and 1 yel/blk wire.
Old Jun 23, 2009 | 08:18 PM
DoubleEx's Avatar
will post pics tomorrow.
Old Jun 24, 2009 | 08:18 AM
hondaluver12's Avatar
Dont want to steal this thread, but has somthing to do with injectors and fords... Will injectors out of a turbo ford probe work? Or are they even much bigger(cc) than stock honda ones?
Old Jun 24, 2009 | 09:57 AM
skipbudlong's Avatar
I would really like to know if they will work as well.
Old Jun 24, 2009 | 10:47 AM
D16SiHatch's Avatar
i have mustang injectors i just put up for sale in the marketplace. 65$ shipped for a set of 4 green top 440cc saturated injectors. http://www.hondamarketplace.com/show...3#post39011783
i believe the probe injectors are 325cc.
Old Jun 25, 2009 | 06:46 AM
DoubleEx's Avatar
The injectors are yellow ford racing injectors that fit on the fox body models. Should be obd1.
Old Jun 25, 2009 | 06:55 AM
DoubleEx's Avatar
denso F1ZE-C2A
Old Jul 30, 2009 | 03:10 PM
DoubleEx's Avatar
got some neon injector plugs (same as mustang and easier to get.)
Old Jul 30, 2009 | 03:15 PM
DoubleEx's Avatar
They are 14.9 ohms so no resistor box right?
wwolf771177
Jan 8, 2012 08:57 PM
HARRY-DA
May 17, 2010 03:25 PM
b16hatche
Oct 24, 2005 08:03 PM
D-meet07
Aug 26, 2005 04:25 AM
Built B16A
Jul 4, 2004 06:05 PM
