Acura Integra 1994-2001 DC2 Shocks and Struts: removal, installation, inspection etc
To see the original article with images check it out here: Integra DC2 Shocks and Struts. Garage411.com
Removal
Raise and support front of vehicle. Remove wheel assembly and brake hose clamp from strut. Remove strut-to-fork pinch bolt and strut fork bolt. Remove strut fork assembly. Remove cap and nuts from top of strut. Remove strut assembly.
FYI: Struts and strut forks are not interchangeable from side to side.
Disassembly
Using a spring compressor, compress spring slightly to remove spring tension. Hold strut rod with Allen wrench and remove spring seat nut. Slowly release spring compressor. Remove spring. Disassemble strut, noting relative position of parts.
Reassembly
Inspect parts for cracks, deterioration, or damage. Check shock absorber for leaks and improper operation. Replace strut if resistance is weak, uneven, or jerky when strut is compressed. Replace worn or damaged parts. Position mounting base with one stud aligned within the following range of the tab on strut housing. To complete reassembly, reverse disassembly procedure.
Acura Integra Strut Housing Alignment: 58.5-64.5 degrees
Installation
1. Loosely install the strut onto the frame with aligning tab facing inside, and loosely install the nuts to the studs in the strut tower holes. Install strut fork onto lower control arm. Position strut assembly so tab on strut housing aligns with slot in fork. Loosely install the bolts and nuts. Place jack under knuckle, and raise it until vehicle just lifts from safety stand.
Strut mount base nuts must be tightened with strut under vehicle load.
2. In the following order, tighten the upper fork bolt, the lower bolt self-locking nut, and the upper strut-tobody nuts. To complete installation, reverse removal procedure. Tighten nuts and bolts to specification.
Torque Specifications - Ft. Lbs. (N.m)
Removal
Disassembly
Reassembly
Installation
- Brake Caliper Bolt: 80 (108)
- Lower Ball Joint Castle Nut: 36-43 (49-58)
- Lower Control Arm Anchor Bolt: 47 (64)
- Radius Arm Bracket Anchor Bolts: 66 (89)
- Radius Arm Nut: 61 (83)
- Spindle Nut: 134 (181)
- Stabilizer Bar Bushing Bracket: 16 (22)
- Stabilizer Link-To-Control Arm Nut: 16 (22)
- Stabilizer Link Ball Joint-To-Stabilizer Bar Nut: 22 (30)
- Strut Fork Pinch Bolt: 32 (43)
- Strut Fork-To-Control Arm Nut: 47 (64)
- Strut Mounting Base Nut: 36 (49)
- Strut Mounting Nut: 22 (30)
- Tie Rod End-To-Knuckle Castle Nut:o 1997: 29-35 (39-47)
o 1998: 32 (43) - Upper Ball Joint Castle Nut: 29-35 (39-47)
- Upper Control Arm Nut: 47 (64)
- Wheel Lug Nut: 80 (108)
- Speed Sensor/Harness Mounting Bolts: 84 inch pounds
- Splash Guard Bolt: 44 (5) inch pounds
This is a great writeup. I got here via Google search for "replace front struts 2000 ACURA integra"
I also found this YouTube video really helpful.
navcc
Apr 8, 2011 03:10 PM
