89' civic hatchy
so, I bought this civic for 100bucks, i bought it for parts but its not in that bad of shape, it runs and drives but not well the motor revs up just fine and stays cool( I let it run for like an hour 1 time, and the ac work really well. but the tranny has no revers, and it has to be jumped if i let is sit for mor than 15 min. no matter how long it runs. all this i can fix. But when i drive it, it wobbles really bad, I havent drove it over 25mph. the steering wheel has a lot of play and it wobbles back and forth pretty bad. the tires are not that good on it and the brakes need replaced, but I dont know why it wobbles like that. my guess would be something is bent with the steering, but I dont know much about that. I am wondering if the shocks and struts would have anything to do with that also? so any help? thanks.
The wobble could be 1 of many things. From my experence though most the time its from the wheel/tires not being ballenced right or a very bad alignement. I would say that your battery is shot for it not wanting to start back up after 15 minutes. Or your alt is very weak at charging the battery.
like he said it could b the ballance..or maby one of the struts is bent that or check the wheel baring it might just b something that simple..it may not cause the wobboling but its worth the try..
Well, I think imma keep it for now,lol. but if i ever deiced to get rid of it, ill let you guys know first. as for the help, ill get the alighnment checked out, and hopefully thats it, if not ill keep you updated. thanks.
Doesn't sound like an alignment problem to me. Sounds more like a bent wheel and/or suspension component. Id check that out before I went and spent money on an alignment. And while you have the front end in the air give the wheels a good shake and see if they have any play in them.
Hondakios
Honda Civic (2006 - 2015)
May 1, 2022 09:28 AM
hondazccivic
Oct 20, 2008 10:30 AM
