Honda S2000 Honda S2000
Honda S2000 Cam Gear Removal and Installation
Old Jun 23, 2009 | 03:46 PM
Master23's Avatar
Default Honda S2000 Cam Gear Removal and Installation
To see the original article with images check it out here: Honda S2000 Cam Gear Removal and Installation. Garage411.com
REMOVAL
1. Remove the dipstick, positive crankcase ventilation (PCV) hose, and breather hose.
2. Remove the ignition coil cover, then remove the ignition coils.
3. Remove the cylinder head cover.
4. Loosen the rocker arm adjusting screws.
5. Remove the camshaft holders and camshafts.
6. Hold the camshaft with an open-end wrench, then loosen the camshaft gear mounting nut.
7. Remove the camshaft gear.
FYI: The exhaust camshaft gear has a groove in the face. The intake camshaft does not have a groove.
INSTALLATION
1. Install the camshaft gear. When installing, note that the exhaust camshaft gear has a groove on its face.
2. Apply new engine oil to the threads of the camshaft gear mounting nut, then install it.
3. Hold the camshaft with an open-end wrench, then tighten the camshaft gear mounting nut.
    CX-Adam
    Transmission & Drivetrain
    Feb 17, 2013 03:57 PM
    BigPlansNoMoney
    Sep 25, 2007 12:53 PM
    HT Chaplain
    May 3, 2005 03:26 PM
    B2FiNiTY
    Jul 31, 2004 08:07 AM
