Integra DC2 Clutch Pedal Height
Old Jun 23, 2009 | 03:34 PM
Master23's Avatar
Default Integra DC2 Clutch Pedal Height
To see the original article with images check it out here: Integra DC2 Clutch Pedal Height. Garage411.com
1. Loosen lock nut "A". Loosen clutch switch until plunger no longer touches clutch pedal. Loosen lock nut "C". Rotate clutch pedal push rod to obtain specified pedal travel and height. Tighten lock nut "C".
2. Turn clutch switch inward until it contacts clutch pedal, then turn it in another 1/4 - 1/2 turn (3/4 - 1 full turn on Integra). Tighten lock nut "A".
3. Loosen lock nut "B". Loosen clutch interlock switch. Measure clearance between floorboard and clutch pedal with clutch pedal fully depressed. Release clutch pedal .59-.79" (15-20 mm) from fully
depressed position and hold it there.
4. Adjust position of clutch interlock switch so engine will start with clutch pedal at this position. Turn clutch interlock switch inward an additional 3/4 - 1 turn. Tighten lock nut "B".
Steven Gilner
Sep 26, 2013 10:20 PM
96H4TCH
Jun 22, 2009 11:19 AM
crazy eyez killa
Apr 2, 2004 11:27 AM
3rdGteg
Nov 14, 2002 07:43 PM
