Having trouble finding the right wires. driver priority unlock for honda accord
Old Jun 23, 2009 | 02:10 PM
vtec.dc2's Avatar
Default Having trouble finding the right wires. driver priority unlock for honda accord
Hi,
I'm unable to find the right wire and location for drivers priority unlock without tapping into door. only wire on factory alarm is for unlock relay.. any help?
I need to connect driver priority unlock wire on 98 accord lx 4 door
Old Jun 23, 2009 | 04:57 PM
fcm's Avatar
fcm
Old Fart
Default Re: Having trouble finding the right wires. driver priority unlock for honda accord
There is no lead for priority door unlock on 98 Accord, if you have that option with OEM remote it is done internally in the door lock control module.
You will need to add a SPDT relay to the drivers door actuator unlock lead.
Cut lead, connect actuator end to #30 other end to #87a 12V+ constant to #87 and #85, and priority unlock lead from alarm to #86. 94
Old Jun 24, 2009 | 05:39 PM
vtec.dc2's Avatar
thanks
i looked all over and i still can't find the other wires.. such as:
1. door trigger - it says on its passenger side, 4 plug connector... but in manual says its for dome light.. which one is the right one?
2. also, having problems finding emergency brake negative cable thats not near emergency brake
3. cant find parking lights either, need negative cable and nothing describes anything concrete
4. trunk - its says grey molex connector near drivers kick.. but i can't find it.. how many pins?
5. hood wire - says passenger side yellow cable, green connector.. but they're all green.. which one is it..
6. dome lights - again, as all other ones, i need negative wire
any help appreciated..
Old Jun 24, 2009 | 06:54 PM
djkurious's Avatar
3. Any red/black wire in the car.
5. I think you have to install the switch for the hood
As far as the other's: http://www.the12volt.com/installbay/...tail/1038.html
Old Jun 24, 2009 | 08:02 PM
vtec.dc2's Avatar
5 installed the switch
4. used orange wire on 2 pin grey connector.. tested .01 at the most and negative at other times.. so it must be it.. the other wire is yellow.. i wonder if its for the hood
6. please don't tell me door trigger and dome lights are the same thing.. cause i spent a whole lot of time trying to figure that one out.. oh well..
its a 4 pin connector that tested positive so i'll have to use a relay, i can't find a way around it. factory plug has input for it put it still shows positive voltage at least .06 .08
Old Jun 24, 2009 | 08:08 PM
vtec.dc2's Avatar
red black is positive.. i need negative for parking lights
Old Jun 25, 2009 | 05:07 AM
fcm's Avatar
fcm
Old Fart
Door trigger is black/white (-) found in pass. side fuse box, it will test as 12V+ with door closed, [dome light switched to "DOOR"] and as a ground when a door is opened.
Yes, door trigger and dome light are the same lead, a relay is needed to supply the ground for dome light supervision is a relay is not built into the alarm brain.
The hand brake, [emergency brake] lead is gray and can be found at switch at base of hand brake.
Park lights neg.(-) is red/yellow in steering wheel harness.
Trunk pin is blue or white in green 42pin plug on top of fuse box.
Hood pin is light blue or yellow/red at pin switch or front of fuse box, not avalable on all models.
All the above depends on exact model/trim level of your Accord.
What is the make and model of the alarm you are installing? 94
Old Jun 25, 2009 | 06:26 AM
vtec.dc2's Avatar
i'm installing compustar pro 2w900
i looked really hard for red/yellow on steering wheel harness.. where exactly? is taped to main ignition harness? i'll keep looking
also,
for i data link, requires data, sync which i can find and ignition wire which i'm not sure about.. or do i just connect it to any ignition wire?
there are 4 wires at key cylinder, red, blue which i know are data and sync... then yellow and brown - are any of these 2 ignition wires?
Old Jun 25, 2009 | 11:40 AM
fcm's Avatar
fcm
Old Fart
Alarm, remote start, or alarm/remote combo unit?
Find harness coming from light switch, red/yellow will be there.
Test the yellow and brown, on of them will be ign., you should be able to use any "true" ign., [hot in run and start].
Again..." All the above depends on exact model/trim level of your Accord" that was a question?
Old Jun 30, 2009 | 06:56 PM
vtec.dc2's Avatar
ok
everything works now except remote start
it gives me 3 flashes.. and on remote says error with door flashing.. any ideas?
i'm not sure if my door trigger is hooked up properly.. it displays 12 plus volts that changes from 12.3 to 12.4 if door is opened or closed
so it doesn't show if my doors are opened or closed
PEI-Accord
Mar 11, 2019 04:53 AM
ronaldrperez
Feb 23, 2017 02:45 PM
Odessa
Audio / Security / Video
19
Aug 3, 2004 06:37 PM
Cycoco
Feb 15, 2004 08:12 PM
95 LS
Jan 30, 2004 09:50 PM
