94 Honda Prelude Brake Calipers on a 94 Accord?
Old Jun 23, 2009 | 01:48 PM
straightshot08's Avatar
Default 94 Honda Prelude Brake Calipers on a 94 Accord?
Can I put 94 honda prelude brake calipers on a 94 honda accord.
And Can I put the brake booster on it also?
Old Jun 23, 2009 | 04:42 PM
Dark_Bolin's Avatar
New User
Default Re: 94 Honda Prelude Brake Calipers on a 94 Accord?
YOU HAVE TO CHANGE EVERYTHING
Old Jun 23, 2009 | 09:34 PM
stereo69's Avatar
depending on the trim level they might be the same but if it's a VTEC prelude then it's the same calipers as the wagen or V6 and will not bolt up and to use them you have to swap the spindle and rotors too.
Old Jun 24, 2009 | 02:44 PM
theforeignkid's Avatar
Prelude V-tech calipers work with v6/wagon 11.2 inch rotors, and 1mm washers to get the bracket to sit properly, idealy you should use another bracket but could get away with the spacer trick. Im not sure the other 2 posters dealt with this before, there is alot of misleading info on the net, you dont have to go rotor over hub if you want to do the 11.2 inch rotor upgrade. Im not sure about the brake booster. Heres the info for the swap w/o ROH. http://www.cd5tuner.com/vbb/showthread.php?t=4
Old Jun 24, 2009 | 04:20 PM
tamadrummer1120's Avatar
And just a suggestion. If you are going to go through the trouble to swap spindle and all that stuff, might as well swap to 5 lug and could get a real nice BIG brake upgrade.
riceburner94si
21
Jan 6, 2012 05:44 AM
paniaguae640
Mar 10, 2008 11:09 PM
bigkevracer
Jan 20, 2008 12:30 PM
bigdaddyvtec
Jun 6, 2006 03:03 AM
