Ti Retainers in my DD a good idea?
Old Jun 23, 2009 | 12:30 PM
cnydc2's Avatar
Default Ti Retainers in my DD a good idea?
Well Ive read a couple instances where people say that the Ti retainers aren't good for dd due to there tendancy to "mushroom" after a while. But on the flip side I see people doing it all the time. Has anybody had any experiences with the Ti retainers failing after a couple years of driving?
Im rebuilding my GSR to mainly stock specs but I am supercharging in a few months and want to beef up my head for some ITR cams in the future. I already have a a complete set of RM gen1 springs and gen2 retainers that I purchased a while back but am now selling because I dont need the huge seat pressure for my mildly cammed and lightly boosted NA, prolly going to go with supertech valves and OEM retainers at this point. Just curious about the Ti Retainers
Old Jun 23, 2009 | 12:37 PM
shifty35's Avatar
Default Re: Ti Retainers in my DD a good idea?
Ti has a tendency to work harden and become brittle while in contact with the spring. It should be considered a wear / consumable item, so if used in a DD, it should be examined / replaced with some frequency. There will be debate about what that frequency is.
For a mild cammed setup, the "benefit" of a Ti retainer will be marginal at best, especially in a non-competition purpose vehicle.
I say skip em.
Old Jun 23, 2009 | 12:51 PM
cnydc2's Avatar
My man, perfectly put! Thats what I was thinking, plus I could use the money elsewhere (maybe some true 2.5" exhaust piping to make my new exhaust).
Old Jun 23, 2009 | 01:04 PM
all-mtr-teg's Avatar
If you choose not to run stock rets. I would suggest the crower steel rets.
Old Jun 23, 2009 | 01:08 PM
cnydc2's Avatar
I've heard that. Is there price roughly the same as Ti or cheaper because of the tact that steel is cheaper? And what gains are there with using the Crowers over OEM? Just the option to run a cam with higher lift?
Old Jun 24, 2009 | 12:28 PM
pgpbubble's Avatar
KMS also makes steel/chromoly retainers that are priced cheap
Old Jun 24, 2009 | 01:05 PM
cnydc2's Avatar
Cool I'll check them out. Hey do you guys know of any where to buy a 2.5" exhaust piping kit for my DC2 so that I can make my own custom exhaust? I know Kteller does but did know if there was anywhere else I could look, maybe a shop that is more active on HT than Kteller.
I posted that question in the FI forum but just had some retard give me nonsence without even reading my original ost.
Thanks Fellas!!
Old Jun 24, 2009 | 01:33 PM
Combustion Contraption's Avatar
So this has basically come down to whatever is cheapest must work best?
Old Jun 24, 2009 | 01:46 PM
cnydc2's Avatar
No not at all, thats actually never the case. But for my project I do have a budget, and at this time I will probably just use my OEM retainers because I dont foresee me needing the ability to run some cams with huge lobes. I was just curious because of a post I saw when searching from 06 or 07. I also wanted to see what all of my options are before I make any decisions
Old Jun 24, 2009 | 01:47 PM
If you're using stock cams, I agree, stock retainers are good to use.
Anytime you start really pushing the RPM, Ti is something to look at. Stay away from KMS.
Old Jun 24, 2009 | 01:49 PM
cnydc2's Avatar
Cool, thanks man. As of right now I'm looking into ITR bumpsticks or something else in a mild street cam. Just out of curiosity, why dont you recommend KMS?
Old Jun 24, 2009 | 04:54 PM
JDMCRX's Avatar
Bump would like to know also.
Old Jun 24, 2009 | 05:10 PM
thabao's Avatar
arnt the ITR retainers steel?
Old Jun 24, 2009 | 05:11 PM
victor.ek4's Avatar
mee too...
Im going to build my head using some of those and BLOX springs, wich are ok to use with stock retainers.
I just tought KMS ones would be slightly better.
My cams are Blox B and revcut will be arround 9k
Old Jun 24, 2009 | 05:31 PM
Originally Posted by victor.ek4
mee too...
I would run Supertech springs if I were you.
Old Jun 24, 2009 | 05:36 PM
00Red_SiR's Avatar
All Motor Mentor
yes.
Old Jun 24, 2009 | 07:09 PM
95 integra's Avatar
I ran a set of Toda A cams, Skunk2 valve springs and stock retainers to 9k with no problems. Ti retainers are great for something more aggressive...I'd personally try to save weight by getting lighter aftermarket valves before I did retainers.
Old Jun 26, 2009 | 05:58 AM
victor.ek4's Avatar
So id better run stock retainers with my blox springs than the kms ones????
Im goin to rev arround 9k....
Old Jun 26, 2009 | 09:58 AM
American.Graffiti's Avatar
Im running supertech springs/retainers on my daily.
Old Jun 29, 2009 | 12:12 AM
mugen mj5's Avatar
From: Where the shooting range is on the streets of LA, CA.
good info
Old Jun 29, 2009 | 03:59 AM
95DC2GS-R's Avatar
the ITR retainers are good, and I've heard great things about the Crower Cromoly/Steel retainers. They're both similar in cost, about $60-70
How high do you plan on revving anyway?
p0gi_b0i_integra
Jan 25, 2008 08:33 AM
R.and.Y
62
Feb 12, 2007 04:19 PM
The Poopsmith
Jun 9, 2003 05:46 PM
teg92
Nov 12, 2001 08:14 PM
teg92
Nov 11, 2001 05:45 PM
