A/C condensor fan wiring...?? (4th gen)
Old Jun 23, 2009 | 12:19 PM
ImPuLsIvE's Avatar
Default A/C condensor fan wiring...?? (4th gen)
Due to having to change to a civic half-rad, I had to remove both the OEM fans. Now, I've hooked up one of the fans for the radiator (which works perfectly), and just acquired a second fan for the A/C condenser. Where is the wiring hook up for this second one? Can I just connect it straight to the A/C Fan Relay (located near the headlight on the driver's side in the engine bay) or is there something else I'm missing?
Also, when I press the A/C button in the dash, I'm not getting anything at all from the system. Shouldn't I feel the compressor turn on even if there's no fan present? What'd be the fix for this?
Any help would be greatly appreciated!
Old Jun 24, 2009 | 05:29 AM
ImPuLsIvE's Avatar
Default Re: A/C condensor fan wiring...?? (4th gen)
Anyone?
Old Jun 24, 2009 | 07:58 AM
red92si's Avatar
Wiring for the a/c fan comes up right next to the drivers side headlight. Two-pin connector same as radiator fan.
The climate control circuit board may need to be re-soldered if you are pushing "A/C" and nothing is happening. It's a common Prelude problem.
Old Jun 24, 2009 | 08:44 AM
ImPuLsIvE's Avatar
So does this mean the compressor WOULD turn on even if there's no fan present? I highly doubt the climate control de-soldered itself as it worked fine before I removed the fan when doing my F/I build.
H0nda_Crazy
May 5, 2013 10:52 PM
krisdog
Jul 28, 2011 12:21 AM
devils_civic
May 13, 2008 01:15 PM
devils_civic
May 7, 2008 12:02 PM
fastlude69
Aug 4, 2005 02:03 AM
