Prelude jerks at steady speed????
Old Jun 23, 2009 | 10:15 AM
r6racer5394's Avatar
New User
Default Prelude jerks at steady speed????
There are no problems with my 97 prelude during driving accept at steady speeds the car jerks. i have to constantly be speeding up or slowing down. this is also the case with the cruise control. anyone ever had problems like this? input would be greatly appreciated.
Old Jun 23, 2009 | 11:53 AM
ceezo70's Avatar
Default Re: Prelude jerks at steady speed????
it sounds like either a egr or cat problem...
Old Jun 23, 2009 | 12:09 PM
New User
thanks im going to check both of those now and give an update.
Old Jun 23, 2009 | 07:50 PM
lude98SH's Avatar
any codes ? Does this happen while cold or hot ?
Old Jun 23, 2009 | 10:07 PM
Stine's Avatar
Sounds like the TPS sensor. Check this by hooking up your multimeter. Unplug the tps and check resistance by putting the negative lead on the middle prong and positive lead to either side. Open the throttle slowly and the resistance should follow as smooth accordingly, from closed to WOT and from WOT to closed. If it does not or is glitchy, theres your problem.
Old Jun 24, 2009 | 07:25 AM
New User
the jerking happens all the time no matter cold or hot or the speed and its only at constant speeds. there are no codes being thrown accept knock sensor sometimes.
Old Jun 24, 2009 | 11:07 AM
toomspeed's Avatar
my money is on the tps sensor. sounds like an issue i had b4.
airikkCRX
Apr 25, 2010 11:23 AM
kmartcivic
Sep 1, 2008 01:51 PM
f22builder
Aug 23, 2006 11:21 AM
SKDRCR
Jul 8, 2006 06:14 PM
DuNkiN
Aug 8, 2001 08:21 AM
