Balance shaft ?
Old Jun 23, 2009 | 10:01 AM
Honda_Mad's Avatar
Default Balance shaft ?
Hi
Did a search but cant find the the info i need, I purchased a balance shaft removal it from Kaizenspeed, at the moment my motor is on a engine stand. In the instruction the motor the install is being done on is bare, what I'd like 2 know is does the crank, rods ect needd 2 be removed. What else needs 2 be replaced? It just seems as if its such an effort 2 install!
Old Jun 23, 2009 | 01:38 PM
DA9racer's Avatar
Default Re: Balance shaft ?
no you don't have to remove all that as long as the girdle is not in the way i can't remember..... when i did mine i had all of it off already.......
Old Jun 24, 2009 | 03:11 AM
hondamark35's Avatar
to install the solid dowels in place of the hollow ones, you'll need to remove the girdle and main caps. you've also got to drill out and tap a hole an inch away from the crank journals... you can do it if your carefull, but i took my crankshaft out.
as far as what needs to be replaced... i would go ahead and replace any seals you have to pull out, or can get to easily (rear main, front crank seal, oil pan gasket and oil-pump pickup tube gasket.. to name a few). otherwise, it should be in your kit! plugs, block off plate...
i'm not sure what Kaizenspeed recommends, but it would be good to use a new rear B-shaft housing o-ring. you may be able to get away with some RTV or Hondabond, but the groove for the o-ring is already there...
Old Jun 24, 2009 | 07:50 AM
egbubble14277's Avatar
no the crank etc does not have to be taken out.
Old Jun 24, 2009 | 09:37 AM
Honda_Mad's Avatar
Thanks for the feedback Guys, really appreciated!
The~boy
Jun 15, 2009 12:01 AM
johnny_tdi
16
Jun 2, 2006 05:37 AM
88whitehatchidaho
Mar 3, 2006 12:08 PM
W O T
Mar 29, 2005 07:47 AM
GruvyTune
Jun 24, 2002 03:59 PM
