ecu help
Old Jun 23, 2009 | 05:35 AM
ej8ster96's Avatar
Default ecu help
so im doing a 5spd converion in my 96 ex coupe, and only thing im missing is ecu, i have found like 574967392058 ecu's for a d16z6, p28, from what i have seen my car needs a p2p, so what im askin is will a p28 work on my car??
Old Jun 23, 2009 | 05:41 AM
vern's Avatar
Default Re: ecu help
you'll need a obd2a to obd1 conversion harness if you want to use a p28
The p28 would run it, but you would probably want it programmed to run the y8 maps.
Old Jun 23, 2009 | 07:37 AM
ej8ster96's Avatar
how much will the conversion cost
Old Jun 23, 2009 | 07:57 AM
vern's Avatar
check www.phearable.net, I believe a harness will run you 75 or so, probably around the same for chipping.
bOOsT-FeIn
May 1, 2011 08:35 PM
profesional-hobo
Texas -OK -LA (Sales)
Apr 3, 2009 02:23 PM
Site123
Engine Management and Tuning
Mar 13, 2009 11:44 AM
Bitchin_Teg
Nov 25, 2005 07:13 AM
