bore size
Old Jun 23, 2009 | 04:55 AM
Team Si by FCC's Avatar
Default bore size
hello
need help, dont no wat would be the best size to bore the cylinders for a poor mans types
Old Jun 23, 2009 | 07:37 AM
Ruben19's Avatar
Default Re: bore size
.20 over
Old Jun 23, 2009 | 07:43 AM
redlinetuning's Avatar
actually, if you gave specifics instead of "poor mans" etc etc... it would be easier to help you with what you are looking to do.
what are your hp goals, NA or boost? Stock bore is sufficient. If you over-bore your block, you'll want to cc your head chambers to match.
Old Jun 23, 2009 | 09:00 AM
well i would like a least 600hp and i was gonna do a gsr block with a b16 itr head.
Old Jun 23, 2009 | 09:11 AM
Hanmin's Avatar
You crazy as hell. Good Luck. Either your dumb, or some genius that knows the ancient secret of Honda's. I pick the latter since you asked this question and said b16 itr head. You will never achieve 600hp with an all motor poor mans setup running 95 octane. I'll end it early for you. It's not going to happen, impossible. Go chase another dream. I don't even think all motor v8's with alcohol can hit 600hp. Do a vitara setup, cheap, and easy. There's one around here that is a drag car, hits 470+hp and hit's 10's. Good luck with 600hp all motor.
Just go to a shop, say you want a poormans type r, and your budget is limitless. Your crazy as hell.
Old Jun 23, 2009 | 09:16 AM
im not crazy i just want a badass car
also i wasnt gonna do all motor i was gonna add **** to it
Old Jun 23, 2009 | 09:36 AM
Ruben19's Avatar
dude, if you want 600 hp get ready to spend some serious $.
first you need to sleeve the block.
Old Jun 23, 2009 | 09:39 AM
yea i no bout the money issue
i now have a new idea for a build, tell me wat u think of it.
i was thinkin of doin a k20a1 head with a k24 block
Old Jun 23, 2009 | 09:42 AM
Ruben19's Avatar
is a great start.
all motor or turbo?
but alot of work if you doing the work.
Old Jun 23, 2009 | 09:43 AM
Bwill9886's Avatar
Good potential. Seems like more and more people are doing this swap and they are making really good power.
If you can hit 600hp, more props to ya. I'd definitely like to see that.
Any idea what you are gonna do to whatever engine you pick to make that goal?
Old Jun 23, 2009 | 10:05 AM
Now you're just e-building your motor. I suggest you do some research. What people think on here should be irrelevant to what you want to do.
There is alot of information on here. Some are good, some are plain stupid, but if you stick to technical data, you'll be fine. Stay away from "I heard this, I heard that BS".
Old Jun 23, 2009 | 01:38 PM
Originally Posted by Ruben19
is a great start.
all motor or turbo?
imma do turbo
nothing big tho, maybe a t26 will do or i may go with a garret t3/t4 peak boost turbo
Old Jun 23, 2009 | 01:40 PM
thanks man for the inspiration
it is gonna be a while till i get it all together. i wil start out with the block do wat i have to do to it then get the head and just keep goin.
i will add pics of my progress.
but thanks once again for the inspiration
Old Jun 23, 2009 | 02:49 PM
98civdx's Avatar
Master Detailer
600whp!?? gl
i know you said you know about the money issue, but have you looked into it? research?
i think the amount of money may sacre you.
Old Jun 23, 2009 | 03:53 PM
yea i researched stuff
i literally came home from school go on H-T and performance shop website and just go crazy with ideas and ?'s. trust me i no
i can get the k20a1 for maybe 400$'s to 700$'s and the k24 block 300$'s to 500$'s. and the tranny idk would cost but i can take a guess it wont be cheap
Old Jun 23, 2009 | 04:52 PM
Hanmin's Avatar
go to the forced induction forum or the all motor forum and see what others have built, what they spent, and the power that they made.
Old Jun 23, 2009 | 07:44 PM
Bwill9886's Avatar
Only advice I have to offer so far is that you are gonna need a bigger turbo to make anywhere close to 600hp.
Maybe you should go with that small turbo first and see what you get. Then build from there.
As Hanmin suggested, check out the forced induction forums. Might help you see what kind of power goals to expect from certain setups.
Old Jun 23, 2009 | 07:46 PM
98civdx's Avatar
Master Detailer
well if you say so lol.
be carefull when buying rsx trannys. they have issues with 2nd and 3rd.
Christopherian1982
Jan 20, 2009 09:52 PM
davidcrx89
12
Jul 5, 2005 11:59 PM
persianprelude
Nov 18, 2003 08:58 PM
lysergican
May 30, 2002 06:42 PM
BlwnBlue
Nov 12, 2001 07:46 AM
