map sensors on back of firewall?!?!
ok this may not matter or i may be a complete idiot for not realizing it before im using the stock map sensor on the back of the firewall for my d15 88, its a 95 obd1 d16 vtec motor is that the reason its doing all this
ok sorry i have an 88 dx civic hatch, i just swapped the motor out of a 95 civic ex, i had the new motor plugged in to the map sensor for my old motor, the stock 88 civic dx one that is located on the firewall, so im guessing that was my problem with it running like ****?
its the black bock looking thing on the top of the firewall with the two plugs and then the vac lines coming out the bottom one goes to the vac cannister
you need a diff map sensor for the obd1 engine. it goes on top the throttle body. the plug from the old one will fit no prob you just have to lengthen the wires is all. you can leave the one unhooked on the firewall. it is now located on the tb. does same job just diff spot
Like he said just unplug the harness from the firewall mounted map and plug it into the map on the throttle body. You don't have to extend the wires to make it reach but it's not a bad idea.
yea with a bit of pulling and movin around itll reach i guess...i just added some slack on mine.
plug it in here on the tb
hmmm, veerd. i didn't have to extend mine anyway
I haven't personally tried to use my obd0 map with my obd1 ecu, however i do not believe that it would work right. they may have the same connector, and same voltage range, however the obd1 map registers up to 1.8 bar, and obd0 only goes to 1.7. thats about a 1.5 psi difference at max voltage. which means that for example 1 bar on an obd0 map is going to provide a slightly different voltage than 1 bar with an obd1 map sensor. the ecu be it obd0 or obd1 is calibrated to the appropriate map sensor. if you use the wrong one, you will very likely be sending the ecu incorrect readings for how much air is getting into the engine.
ok im buying one tomarrow and putting it on hopefully this will be the end to my problems i just wanna dive this thing already thanks for everyone thats been helping ive beeen building cars since i was 15 but as far as hondas go im a def noob
Archie_G
Oct 21, 2004 05:46 PM
