..96 teg ls prob..
Old Jun 22, 2009 | 07:04 PM
donth8me's Avatar
New User
Icon3 ..96 teg ls prob..
ok I have a 96 teg ls, first off I have changed within last month the followin: fuel filter & injectors, distributor cap & rotor & ignition coil, spark plugs, ac fan, oil & air filter. but I'm still havin this followin problem, when the car is cold it starts up great, as the car gets warmer and say I'm in bumper to bumper traffic, she tends to bog out and dip in rpm. so I got to rev it pass 4000 rpm, and then it's fine, but then say after drivin couple miles, and I go in the store I have to wait til the car cools down for it to start with no problem. it doesn't overheat so that's not the problem. fans work. wat can be the problem. pls help a lady out. thanks in advance.
Old Jun 23, 2009 | 11:54 AM
donth8me's Avatar
New User
Default Re: ..96 teg ls prob..
to the top
Old Jun 24, 2009 | 10:48 PM
my_gsr_teg's Avatar
so are you saying the car has a idling problem? and what do you mean specifically when it bogs out and dip in? a bit more detail please
Old Jun 24, 2009 | 10:59 PM
ek-g6's Avatar
I think she means it bogs from 3000 rpm going 4000 rpm and needs to step on gas to get it past 4k then it'll go normal without the bog. I had the same problem and for the life of me I couldn't figure it out I replace all the intake manifold sensors, but nothing, did a major tune up and still nothing, and I end up replacing the fuel rail and fuel pressure regulator, and it was fixed! Not sure if fuel rail was clogged or the fpr went bad, but it fixed my problem and it may fix yours.
Old Jun 25, 2009 | 03:16 AM
spooledinurface's Avatar
Is it smoking? I had the same problem and it was the head gasket would heat up and let coolant get on cylinder so would not start after being warm and Idled funny.
Best of luck to you
Old Jul 18, 2009 | 04:42 AM
donth8me's Avatar
New User
I have changed so many things. Ugh I have yet to figure the problem out. She idles funny after bein ran for awhile, or if I let her sit for to long after bein ran. Den wen I get it started it idle low, and try rev it but it will stay low and jus die out. Pls pls help me. Somebody told me my IACV could be dirty and I need to clean that put.
BladesTeg
Mar 3, 2011 09:01 AM
danteisme
Apr 21, 2009 10:10 AM
beanzo123
Dec 14, 2007 09:38 PM
8200RPM
May 11, 2004 08:01 PM
8200RPM
May 2, 2004 10:09 AM
