Heat/AC problem
I have a 94 eg coupe and i purchased the car a couple of months ago..there are no noteable problems with the car other then the heat and Ac. I dont know if its the controls on the dash oe what..But no matter what i put the temp on it will run the same as the outside temp..so i have no AC and no Heat..and am running out of conclusion can anyone help my cause...I have plenty of coolent and such i just have no AC and Heat..LMk what you guys got..
Thanks
BLACKDIAMOND
Thanks
BLACKDIAMOND
Heater: Check whether the heater cable from the panel fails to move the heater valve on the firewall.
A/C: When you push the A/C button, does the A/C light turn ON, the compressor clutch engage, and the condenser fan run?
Will do i will update tmmrow with my results thanks alot..i know the AC light turns on..i do know that much as for the fan and compressor i havent payed atention. so i will let you know
thanks
blackdiamond
thanks
blackdiamond
94_civicEx
Honda Civic (2006 - 2015)
Jun 13, 2014 12:28 AM
