BRAKE PROPORTIONING VALVE???
Old Jun 22, 2009 | 03:14 PM
dblock8989's Avatar
Default BRAKE PROPORTIONING VALVE???
I was wondering if a 95 integra... or any DC brake prop valve fit my 94 integra RS..thanks in advance.....
Old Jun 22, 2009 | 06:20 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: BRAKE PROPORTIONING VALVE???
Well, most Integra's have ABS and dont have prop valves - they have the ABS modulator instead.
So if you find a DC Integra without ABS - then it has to have a prop valve and therefore yes, it'll fit your 95'.
Old Jun 23, 2009 | 12:30 PM
ahcapone's Avatar
All Integras have prop valves. They work in conjunction with the ABS modulator. Only the RS comes without ABS so you need an RS(40/40) prop valve.
Old Jun 24, 2009 | 11:54 AM
dblock8989's Avatar
IIGHT THANKS I HAVE AN RS SO THATS WHAT I HAVE TO LOOK 4 THANKS IN ADVANCE
Old Jun 24, 2009 | 01:37 PM
94EG8's Avatar
Seagull Management
'94 - '97 Integra non ABS prop valve is what you want. '90 - '93 should work fine as well. '98 - '01 aren't the same (MC and prop valve look the same as those from a '96 - '00 civic)
Old Jun 24, 2009 | 01:54 PM
CARMA_626's Avatar
Is it an internal prop valve within the ABS modulator? Because when I removed my ABS and brake lines, I didnt see any proportional valve at all.
Old Apr 25, 2016 | 10:12 AM
Osek_818's Avatar
Is this still alive have a question pls help
Old Apr 25, 2016 | 03:55 PM
TheRealTegger's Avatar
Start a new thread for your new problem.
9threEJ
Aug 1, 2018 07:11 AM
spoonb16b
Mar 6, 2015 02:36 PM
ZCHondaCRX91
Suspension & Brakes
Feb 4, 2012 09:18 PM
_gurusan_
Mar 16, 2005 05:10 PM
piscorpio
Apr 5, 2002 02:49 PM
