oil leaking from intake filter?
Old Jun 21, 2009 | 11:56 PM
medorihb's Avatar
Default oil leaking from intake filter?
i took the y8 head off because it was running like crap and put the y7 back on and it runs like it used to....except now there is oil dripping from the intake filter and when you pull the dipstick out there is an oily vapor coming out.
1. Is this oil possibly residual from the y8 having bad valve seals/seats, and the compression was pushing the oil into the intake.
2. Is it possible that my rings are bad....only 2 years old...but the compression is higher than stock.
3. Is it possible that the piston skirts are wearing
4. could it be a bad pcv causing the oily vapor from the dipstick tube.
any help would be greatly appreciated.
Old Jun 22, 2009 | 08:08 AM
medorihb's Avatar
Default Re: oil leaking from intake filter?
bump for some help
Old Jun 22, 2009 | 11:38 AM
civic_driver's Avatar
Yeah, I was thinking PCV valve before I read your post so I would try replacing it with a new one and see if that changes anything.
Old Jun 22, 2009 | 03:25 PM
cnydc2's Avatar
I'd start with a pcv, and maybe flush the engine.
Old Jun 22, 2009 | 07:10 PM
medorihb's Avatar
well as ive been driving it...it seems that the oil is less and less.....i'm thinking whatever soaked into the filter from the bad head is just slowly dripping away....i'll do the pcv sometime this week and go from there.....i need to quit dicking with this motor, everytime i get a whim to try something different. thanks guys.
JDMPoochie
May 21, 2009 06:04 PM
kame1997
Mar 31, 2006 12:41 PM
Mike banX
Oct 9, 2004 09:24 PM
EG6 SiR
Aug 4, 2004 07:50 PM
ZUL8R
Nov 18, 2003 06:14 PM
