D16Z6 Swap Wont Start
Old Jun 21, 2009 | 08:55 PM
ted_dejong's Avatar
Default D16Z6 Swap Wont Start
Just swapped into a 92 Civic DX D15B7 to a D16Z6 used DX wiring harness but added VTEC wires. P28 ECU. Automatic transmission. The engine cranks but won't start. Im getting spark. Tested this but grounding it to valve cover. All spark plugs sparked. I checked the fuel and spark plugs smelt and appeared to have gas on them. Timing belt appears to be correct and lines up with TDC. Any ideas.
Old Jun 21, 2009 | 11:50 PM
apexi_rsx's Avatar
Default Re: D16Z6 Swap Wont Start
u check for fuel to see if ur fuel pump priimed? check fuses
mjsullivan89
Aug 22, 2016 08:43 PM
ted_dejong
Jun 22, 2009 05:45 PM
hmtcrxsir
13
Jan 19, 2008 06:06 PM
HTLuver
27
Aug 3, 2006 10:37 AM
Sho Pow
Sep 27, 2004 08:20 PM
