Dents. Pop or filler?
Old Jun 21, 2009 | 06:39 PM
EFinawesomeman's Avatar
Default Dents. Pop or filler?
I plan on repainting my 97 DX soon, there are quite a few of little dings and dents. The worst dent is about 2 inches big. I'm going to do the prep myself and have Maaco do the job since I am not a painting type of guy. I just rattle can. Would it be better to just have the dents popped or whilst prepping just use filler?
Old Jun 21, 2009 | 07:26 PM
bsmith100's Avatar
Default Re: Dents. Pop or filler?
It is always better to pop the dent out if possible.
Old Jun 21, 2009 | 07:27 PM
itslogz's Avatar
If theyre really small like pinky tip, just grind down and use filler. If theyre slightly bigger, a stud gun is a good thing to have from what i've learned. Trying to pull it out as much as possible with a stud gun, then using minimal filler is the best option.
Old Jun 21, 2009 | 10:27 PM
Alright. Think a stud gun is a good investment? I don't really do much body work though.
Old Jun 22, 2009 | 12:49 AM
itslogz's Avatar
Stud gun is a real good investment (Slide hammer needed with it of course) if you plan to ever remove dents/partially remove dents again on any car in the future.
http://www.amazon.com/Magna-Spot-100.../dp/B000HHW1HG
$181 for that kit with the slide hammer, im sure you can find them cheaper thoug, thats just a example.
Old Jun 22, 2009 | 07:47 AM
icucnme's Avatar
Small door dings and such you just need some icing. Feel with your hand and make sure there are no high spots around the dent. If there are then you will have to tap them down gently with a hammer and then fill with icing. Make sure you go a bit bigger then the ding b/c you want to be able to blend it into the car. It's not hard just takes some time.
Old Jun 22, 2009 | 01:17 PM
shocker911's Avatar
smaller dents you can fill over but the dent that is about 2 inches if you can get to it fromn the back side pound it out with a body hammer. then once you have it out as far as you can get it filler it and make sure to feather edge ALL filler spots or it will look like hell when its painted
90civicstdgold
Apr 12, 2010 01:39 PM
SPOOLINmatt
Jan 19, 2010 07:10 AM
avaldez
Welding / Fabrication
12
Jun 11, 2009 08:33 AM
AllMotorHB
Oct 11, 2003 07:59 PM
95civiccoupe31
13
May 29, 2002 06:38 AM
