Overheat help please!!!
Old Jun 21, 2009 | 04:30 PM
b18buck's Avatar
Default Overheat help please!!!
Here goes any help would be appreciated. i have a 91 hatch b18c1 swap. recently did head gasket, water pump, thermostat.. as in about 1 month ago. today as i was driving home temp went from normal to dead cold. pulled off the road coolant was on front of motor but no leak, im not stupid let it cool down and checked for the leak no drips. coolant was low in resivoir and out in radiator.. also top hose was extremely hot and bottom was norm if not a little cool. any thought on what the hell i should do would be great as it is my daily driver. thanks guys!
Old Jun 21, 2009 | 05:18 PM
ek-g6's Avatar
Default Re: Overheat help please!!!
Maybe thermostat went bad and temperature sensor went out also?
Old Jun 21, 2009 | 05:36 PM
sh!ft's Avatar
Who the fack changed my title?!
same thoughts as well^^
Old Jun 21, 2009 | 05:55 PM
b18buck's Avatar
thanks guys< could the thermostat really have gone bad already?? also i was looking and there is a small crack in the top hose, doesnt seem to leak tho.
Old Jun 21, 2009 | 06:04 PM
photec2's Avatar
maybe your ratiator is plugged? I have had that happem before. Temp sensor plug vibrated off?
Old Jun 21, 2009 | 06:16 PM
raffaelli's Avatar
It went dead cold, sounds odd.
Air into the system will decrease the boil temp. Change everything that leaks. If it is still getting hot, chances are you have a clogged radiator.
Joshable14
Jul 20, 2015 10:10 AM
klewis50
Jul 2, 2013 09:55 PM
rebuiltSI
Jun 7, 2007 01:14 PM
PyeeK
Mar 17, 2006 11:55 PM
jadugartir
Aug 4, 2005 12:15 PM
