??? How do you do this???
Old Jun 21, 2009 | 04:27 PM
killercrx91's Avatar
Icon2 ??? How do you do this???
I bean look around and I didn't find anything..... So i'm this goin to ask then. I heard that you can put an rear sway bar on an CRX but how? Is there some kit that you can buy to get it in or do you have to screw in brakets?
Old Jun 21, 2009 | 05:02 PM
90_EX_Civic's Avatar
Default Re: ??? How do you do this???
a lot of suspension company's sell different kinds of kits.
one for a car that has or came with a rear sway bar,
and one that never came with one.
progress and eibach both sell these kits.
oh, and you're looking to buy the kit that is for a crx that didn't have the rear sway bar. the kit will come with custom brackets for the end links.
Old Jun 21, 2009 | 05:14 PM
pandarex's Avatar
it came stock on si's. you need the brackets, lower control arms, and sway bar. or jsut buy a suspension techniques sway bar kit
Old Jun 21, 2009 | 05:18 PM
redsi89's Avatar
i took the rear sway bar off my crx and put on a ST 19mm sway bar with brackets and everythign you need. probably one of the best purchases I've made for my car to date
Old Jun 21, 2009 | 05:38 PM
sh!ft's Avatar
Who the fack changed my title?!
i found my neuspeed bar at the junk yard. VERY good bargan for 5 bux lmao
Old Jun 21, 2009 | 05:41 PM
only thing about this is that i don't know if the brackets will bolt up. if it's the same problem i have, the holes for the brackets are there, but there is no nut on the other side to thread the bolt to it. this is the case in point for the 4door, im not 100% sure if this implies for all civic's with out the rear bar.
Old Jun 21, 2009 | 06:08 PM
ok thanks for the help guy =D
grandtheftlunchbox
23
Nov 4, 2008 08:06 PM
grnaccord
May 15, 2007 01:14 PM
pny1981
Sep 27, 2005 10:35 PM
MaaseyRacer
Aug 17, 2004 09:40 PM
gubo22
Sep 3, 2003 12:57 AM
