Dreaded P0420 code, replaced cat
Hey guys, haven't posted here before but I've been posting on civic forums for quite awhile. I'll get right to the point, I need to take an emissions test in the next couple of weeks, and I have a P0420 code that I can't seem to get rid of. I've replaced the catalytic converter already, and I'm thinking of switching out the o2 sensors but I want to make sure that's the logical next step. Also the idle on my car (2000 civic so with 120K miles or so), is a little jumpy. I've checked for exhaust leaks and I can't find any, so I'd appreciate the help. Thanks in advance guys.
Oh and also, I've reset the code a few times and it doesn't come back on until after a few days of driving or so. It doesn't seem to be effecting drivability at all besides the idle (I'm not sure if this is a related issue or not), so it's just kind of a nagging problem that needs to be resolved because it won't pass emissions with the code. Thanks again.
From: Howcome we park on driveways, and drive on parkways?
all sensors and plugs correctly in place? the jumping idle is most likely from a vacuum leak or a IAC Valve. Im not sure about the code...
Are your sensors aftermarket or OEM o2 sensors? Before throwing parts you should look at the o2 patterns with a scan tool and see if the sensors are giving correct readings? Where did you get the cat from? OEM? Answer some of these questions, and PM me and I can try and point you in the right direction!
