Car wont run forward
Old Jun 21, 2009 | 02:02 PM
tfeagley's Avatar
Default Car wont run forward
Strange issue here. Did a b16a turbo swap into my ej8. I can drive the car in reverse all day however when i put it in gear and try to move forward it chokes and dies. Im getting air / fuel / spark. My main relay clicks when it wants to choke and hiccup. The main relay was just changed since i had a bad one. Could a bad thermostat ground be the issue? Possible clogged fuel filter? Any advice is welcomed. Im about to set this damn thing on fire!
Old Jun 21, 2009 | 02:59 PM
tfeagley's Avatar
Default Re: Car wont run forward
bump
Old Jun 21, 2009 | 05:14 PM
1nsoman1ac's Avatar
i dont know much about the fitiings of the cv axles but did u get the correct ones...i know it doesnt make sence that u can reverse but not go forward. fuel filter should be fine since you can drive in reverse. try to get a main relay from the scrap yard...the new one might be a fluke. check all your grounds. check your TPS. might have been bumped when putting the engine in. just throwing some stuff out there.
Old Jun 21, 2009 | 05:28 PM
tfeagley's Avatar
I calibrated the TPS so i know that isnt the issue. The relay is working fine and the axles came out of a dc2 gsr. thanks for the input though
Old Jun 21, 2009 | 05:31 PM
1nsoman1ac's Avatar
what does it do when you put it in gear and step on the gas?
Old Jun 23, 2009 | 05:58 PM
tfeagley's Avatar
turns out it was the thermostat ground. runs great now.
fitbkeco
76
May 8, 2013 04:14 PM
sw96
Oct 13, 2010 06:00 AM
Lb1atx
Aug 1, 2007 10:52 PM
ludecrasy87
Dec 30, 2006 12:40 PM
CivicBoi
Aug 10, 2003 12:41 PM
