Car wont run forward
Strange issue here. Did a b16a turbo swap into my ej8. I can drive the car in reverse all day however when i put it in gear and try to move forward it chokes and dies. Im getting air / fuel / spark. My main relay clicks when it wants to choke and hiccup. The main relay was just changed since i had a bad one. Could a bad thermostat ground be the issue? Possible clogged fuel filter? Any advice is welcomed. Im about to set this damn thing on fire!
Re: Car wont run forward
i dont know much about the fitiings of the cv axles but did u get the correct ones...i know it doesnt make sence that u can reverse but not go forward. fuel filter should be fine since you can drive in reverse. try to get a main relay from the scrap yard...the new one might be a fluke. check all your grounds. check your TPS. might have been bumped when putting the engine in. just throwing some stuff out there.
sw96
10-13-2010 06:00 AM
