Built GSR high compression question kinda confused...???
Old Jun 21, 2009 | 01:19 PM
pettyboy69's Avatar
Default Built GSR high compression question kinda confused...???
Ok so i bought this 94 gsr 2200 bucks been putting tons of money time and
even a new paint job into it and i did a compression check on it right when i got it and i
have been kinda wondering what kind of numbers psi wise 12:1 high compression forged
pistons should throw out cuz i did a compression check right when i got it and after i had
anthony tune it with bigger fuel system and both times the compression was between 230
and about 245 ish between all the cylinders. If the pistons are 12 to 1 shouldnt it be
higher than that?
like around 275ish? its also a fresh motor only bout 2000 miles since the build lmk what you
guys think and know bout high compression cuz im totally new to it thanx. Oh ya also was
thinkin bout boosting it on like 5lbs to help it sell quik style cuz the car moves about the
same as a stock gsr maybe a little faster but not like high compression should anyway thanx
in advance
Old Jun 22, 2009 | 07:39 AM
ruffrhyder's Avatar
Default Re: Built GSR high compression question kinda confused...???
Merely installing higher compression pistons doesn't mean you will gain a significant amount of power. Perhaps a few hp by itself. Had you installed some aftermarket cams that would require 12:1 CR, then you should see some significant gains. Also, what were your compression numbers before the rebuild? If they were much lower, say 140 psi, I wouldn't be concerned with 240 psi as long as they are withing the acceptable range. If your numbers were similar to 240 psi before the rebuild, then I would be worried. Was the block honed to ensure proper ring seal?
soon2bdropped
Oct 3, 2007 06:28 PM
genop
Sep 17, 2003 10:45 PM
K20 EG
Jun 17, 2003 11:26 AM
TeStUdO
May 5, 2003 05:28 PM
sushibug
Apr 3, 2002 05:04 PM
